Ir para o conteúdo principal
How to clean Game Boy Advance buttons
Adam
Adam e 5 outros colaboradores
Última atualização em February 19, 2025
5 minutos
Muito fácil
Introdução
Ir para o passo 1
Use this repair guide to clean sticky buttons.
O que você precisa
Ferramentas
  1. How to clean Game Boy Advance buttons, How to clean Game Boy Advance buttons: passo 1, imagem 1 %32 How to clean Game Boy Advance buttons, How to clean Game Boy Advance buttons: passo 1, imagem 2 %32
    • Use a slightly damp toothbrush to scrape in between the desired sticky buttons. You can also use a bit of isopropyl alcohol.
    • Make sure toothbrush is not to the point of dripping water when scraping.
  2. How to clean Game Boy Advance buttons: passo 2, imagem 1 %32
    • Dry with a cloth after the sticky residue is removed.
Linha de Chegada
10 outras pessoas executaram este guia.
Adam
Membro desde: 01/20/10
851 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 16-29, Maness Winter 2010 Membro de Cal Poly, Team 16-29, Maness Winter 2010
CPSU-MANESS-W10S16G29
5 Membros
Autoria de 62 guias
3Comentários do guia
I just used this method to clean sticky buttons on a wireless Xbox 360 controller. The Back, Xbox Guide, Start, X, Y, B, and A buttons were all sticky and unresponsive.
I removed the battery pack and followed the steps, and it worked like a charm. All of the buttons work just fine now except for the Xbox Guide button, which isn't really a big deal anyway.
This method works great. Thanks for making this guide, Adam.
Jeff Laxson - Responder
Wow. I thought I was going to have to buy a new Wii U Pro Controller, but this fixed my sticky B button. So simple. Thanks for saving me $50, friend.
Trevor Babcock - Responder
my d-pad needs cleaning, help?
Trace Ruby - Responder
Comentar
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 15
Últimos 30 dias: 94
Ao todo: 28,197
