Ir para o conteúdo principal
How to Unclog a Shark Rocket Deluxe Pro Vacuum
Savannah Webb
Savannah Webb e um outro colaborador
Última atualização em August 31, 2021
15 minutos
Fácil
Introdução
Ir para o passo 1
If your Shark Rocket Deluxe Pro Vacuum (model number HV322) isn’t rolling or sucking, chances are there’s a clog inside the vacuum. Not all clogs are easy to see, so this guide will show how to troubleshoot all the major areas clogs can occur; inside the filters, the rollers, the dustbin, and the tube.
O que você precisa
  1. How to Unclog a Shark Rocket Deluxe Pro Vacuum, How to Unclog a Shark Rocket Deluxe Pro Vacuum: passo 1, imagem 1 %32 How to Unclog a Shark Rocket Deluxe Pro Vacuum, How to Unclog a Shark Rocket Deluxe Pro Vacuum: passo 1, imagem 2 %32
    • Press the wand release button to remove the vacuum body from the roller brush and wand.
  2. How to Unclog a Shark Rocket Deluxe Pro Vacuum: passo 2, imagem 1 %32 How to Unclog a Shark Rocket Deluxe Pro Vacuum: passo 2, imagem 2 %32
    • Press the button at the bottom of the power cord on the dust bin.
    • Pull off the attached piece.
    • Remove the small filter from the piece.
  3. How to Unclog a Shark Rocket Deluxe Pro Vacuum: passo 3, imagem 1 %32 How to Unclog a Shark Rocket Deluxe Pro Vacuum: passo 3, imagem 2 %32
    • Pull the lever on top of the dust bin to expose the main filters.
  4. How to Unclog a Shark Rocket Deluxe Pro Vacuum: passo 4, imagem 1 %32 How to Unclog a Shark Rocket Deluxe Pro Vacuum: passo 4, imagem 2 %32 How to Unclog a Shark Rocket Deluxe Pro Vacuum: passo 4, imagem 3 %32
    • Carefully squeeze and remove the top filter.
    • Underneath that filter is a second filter. Pull the tab to remove it.
  5. How to Unclog a Shark Rocket Deluxe Pro Vacuum: passo 5, imagem 1 %32 How to Unclog a Shark Rocket Deluxe Pro Vacuum: passo 5, imagem 2 %32 How to Unclog a Shark Rocket Deluxe Pro Vacuum: passo 5, imagem 3 %32
    • Squeeze the release on the bottom of the dustbin.
    • Remove the dust bin from the base.
    • Pop the lid open using the slider.
    • Empty the dust bin into the trash.
  6. How to Unclog a Shark Rocket Deluxe Pro Vacuum: passo 6, imagem 1 %32 How to Unclog a Shark Rocket Deluxe Pro Vacuum: passo 6, imagem 2 %32 How to Unclog a Shark Rocket Deluxe Pro Vacuum: passo 6, imagem 3 %32
    • Rinse and wipe the plastic pieces removed earlier.
    • Do not use soap.
    • Set the pieces aside to air-dry.
  7. How to Unclog a Shark Rocket Deluxe Pro Vacuum: passo 7, imagem 1 %32 How to Unclog a Shark Rocket Deluxe Pro Vacuum: passo 7, imagem 2 %32 How to Unclog a Shark Rocket Deluxe Pro Vacuum: passo 7, imagem 3 %32
    • Place the filters in your sink and rinse out the dirt.
    • Squeeze out any excess water and allow them to air-dry overnight before reinstalling.
    • DO NOT USE SOAP.
  8. How to Unclog a Shark Rocket Deluxe Pro Vacuum: passo 8, imagem 1 %32 How to Unclog a Shark Rocket Deluxe Pro Vacuum: passo 8, imagem 2 %32 How to Unclog a Shark Rocket Deluxe Pro Vacuum: passo 8, imagem 3 %32
    • With a wet rag wipe out any dirt buildup on the vacuum casing.
  9. How to Unclog a Shark Rocket Deluxe Pro Vacuum: passo 9, imagem 1 %32 How to Unclog a Shark Rocket Deluxe Pro Vacuum: passo 9, imagem 2 %32 How to Unclog a Shark Rocket Deluxe Pro Vacuum: passo 9, imagem 3 %32
    • Turn the base of the vacuum on its side.
    • With your scissors, cut any wrapped hairs or strings that may be stuck on the rollers.
  10. How to Unclog a Shark Rocket Deluxe Pro Vacuum: passo 10, imagem 1 %32 How to Unclog a Shark Rocket Deluxe Pro Vacuum: passo 10, imagem 2 %32
    • Lastly, insert your drain snake into the tube of the vacuum to dislodge any large stuck items.
Conclusão
Savannah Webb
Membro desde: 06/13/21
181 Reputação
Autoria de 1 guia
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 14
Últimos 30 dias: 66
Ao todo: 2,561
