How to Shorten a Watch Band
Introdução
Ir para o passo 1This guide is an easy way to shorten the band of a wristwatch by removing the watch links. Watch bands are manufactured longer so they can be adjusted to your wrist size. You should complete this guide on a table or sturdy work surface. I recommend to save any watch links you remove from the watch just in case you need them in the future.
O que você precisa
Place a nail in the hole on the opposite side of the arrow.
Gently tap the nail into the hole with a small hammer.
6 outras pessoas executaram este guia.
1Comentário do guia
Never knew how easy it was until I went through this guide. Appreciate how simple you made it
