Ir para o conteúdo principal
How to Rip a Seam
How to Rip a Seam
Brittany McCrigler
Brittany McCrigler e 3 outros colaboradores
Última atualização em August 1, 2017
10 - 15 minutos
Fácil
Guia em destaque
Patagonia
Introdução
Ir para o passo 1
Knowing how to rip a seam is essential for basic sewing and clothing repair. Whether you want to make alterations, replace a zipper, or fix a sewing mishap, ripping the seam properly will make the changes nearly invisible.
O que você precisa
A iFixit ganha comissão quando você compra por estes links.
  1. How to Rip a Seam, How to Rip a Seam: passo 1, imagem 1 %32 How to Rip a Seam, How to Rip a Seam: passo 1, imagem 2 %32
    • Slip the sharp end of the seam ripper through a single stitch in the seam you want to remove.
    • Be sure your seam ripper goes through only the stitch, not the fabric, or you could puncture/tear the fabric.
    • Slide the seam ripper forward, bringing the stitch into the crux of the seam ripper's fork and onto the blade.
    • Gently push the seam ripper forward, cutting the thread.
    • Rely on the blade to do the work. Do not apply a lot of force, as the seam ripper can slip and puncture the fabric.
  2. How to Rip a Seam: passo 3, imagem 1 %32
    • You can use the method described in steps 1 and 2 to completely rip any seam. However, if you have a seam that binds two pieces of fabric, it is easier to rip the seam using the method described in step 4, below.
    • In order to use the method in Step 4, you need to remove the first few stitches of the seam using the method we already described in Step 1. Removing these stitches enables you to separate the two pieces of fabric and use the seam ripper on the stitches that hold them together.
    • Using the method below also helps prevent accidental puncturing of the garment.
  3. How to Rip a Seam: passo 4, imagem 1 %32 How to Rip a Seam: passo 4, imagem 2 %32
    • Separate the two pieces of fabric held together by your seam.
    • Bring the sharp end of the seam ripper between the two pieces of fabric.
    • Slip the sharp end of the seam ripper beneath one of the stitches. Be careful to avoid catching the fabric.
    • Slide the seam ripper forward. Bring the thread into the crux of the fork and onto the blade.
    • Gently push the seam ripper forward again, cutting the thread.
    • Continue working, stitch by stitch, until the seam has been removed. Take your time, being careful not to damage the fabric.
    • Remove all of the loose threads from the ripped seam to prevent tangling when you resew the seam.
Linha de Chegada
6 outras pessoas executaram este guia.
Brittany McCrigler
Membro desde: 03/05/12
89.971 Reputação
Autoria de 142 guias
Equipe
iFixit Membro de iFixit
Staff
121 Membros
Autoria de 19.806 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 79
Ao todo: 25,748
