Ir para o conteúdo principal
How to Restore Wooden Cooking Utensils
Danica Dela Pena
Danica Dela Pena e 6 outros colaboradores
Última atualização em April 16, 2025
25 - 30 minutos
Muito fácil
Introdução
Ir para o passo 1
If your wooden cooking utensils are worn-down, stained, or fuzzy, use this guide to restore your wooden cooking utensils and extend their lifespan.
Wooden cooking utensils are often used, and they wear down over time with regular use. Small chips and dents can trap bacteria, so sanding down your utensils makes them more hygienic. With repeated washing, the natural oils in the wood get stripped away, leaving the wood looking dry. This makes the utensil likely to split and crack. Oiling the utensils prevents this problem.
(A note about boiling wooden tools: There is conflicting information about whether boiling wooden utensils safely sanitizes them, or actually damages them. Putting wooden utensils in boiling water will strip away the wood's oil. It has a high risk of causing them to warp or crack. For this reason, boiling is not recommended in this guide. Washing your tools with soapy water, sanding them and oiling them is the best way to sanitize them and keep them intact.
Sources: (1), (2).)
Before getting started, inspect your wooden cooking utensils to assess how damaged they are. There may be stains, chips, dents, cracks, or worn-down edges. This guide teaches you how to restore wooden utensils with minor signs of wear. It cannot be used to restore a large crack.
  1. How to Restore Wooden Cooking Utensils, How to Restore Wooden Cooking Utensils: passo 1, imagem 1 %32 How to Restore Wooden Cooking Utensils, How to Restore Wooden Cooking Utensils: passo 1, imagem 2 %32
    • Smoothen your worn-down wooden cooking utensils with the sandpaper.
  2. How to Restore Wooden Cooking Utensils: passo 2, imagem 1 %32 How to Restore Wooden Cooking Utensils: passo 2, imagem 2 %32
    • Wash the wooden cooking utensils under warm water and dish soap. Rinse well.
  3. How to Restore Wooden Cooking Utensils: passo 3, imagem 1 %32 How to Restore Wooden Cooking Utensils: passo 3, imagem 2 %32
    • Dry your utensils with a kitchen towel.
    • Leave your utensils to dry off completely before proceeding to the next step.
  4. How to Restore Wooden Cooking Utensils: passo 4, imagem 1 %32 How to Restore Wooden Cooking Utensils: passo 4, imagem 2 %32 How to Restore Wooden Cooking Utensils: passo 4, imagem 3 %32
    • Rub food-grade mineral oil on wooden cooking utensils, using light pressure to help the wood absorb the oil.
    • Apply just enough oil so the tool no longer looks or feels dry.
    • If the tool gets slippery or glossy, there is too much oil. Wipe off the excess with paper towels.
  5. How to Restore Wooden Cooking Utensils: passo 5, imagem 1 %32
    • Enjoy your renewed wooden cooking utensil.
Conclusão
Repeat when necessary to ensure long-lasting wooden utensils.
3 outras pessoas executaram este guia.
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 18
Últimos 30 dias: 85
Ao todo: 3,706
