Ir para o conteúdo principal
iFixit uses cookies to enhance site functionality, analyze traffic, and personalize ads. By using our site, you agree to our cookie use and Privacy Policy.
How to Reset / Restore Windows Tablet
ZFix
ZFix e 3 outros colaboradores
Última atualização em 21 de jun de 2025
25 - 45 minutos
Muito fácil
Guia colaborativo
Introdução
Ir para o passo 1
If you have forgotten Password, PIN, if you want to erase or refresh your tablet, you can do reset your tablet from the Troubleshoot menu.
Warning! A reset returns Surface to its factory settings!
Vídeo de Apresentação
  1. How to Reset / Restore Windows Tablet, How to Reset / Restore Windows Tablet: passo 1, imagem 1 %32 How to Reset / Restore Windows Tablet, How to Reset / Restore Windows Tablet: passo 1, imagem 2 %32 How to Reset / Restore Windows Tablet, How to Reset / Restore Windows Tablet: passo 1, imagem 3 %32
    • Connect the charger.
    • Select "Ease of Access".
    • Open "On-Screen Keyboard".
  2. How to Reset / Restore Windows Tablet: passo 2, imagem 1 %32 How to Reset / Restore Windows Tablet: passo 2, imagem 2 %32 How to Reset / Restore Windows Tablet: passo 2, imagem 3 %32
    • Tab the Shift key.
    • Reset the tablet.
    • After the reset the tablet will start in Troubleshooting mode.
    Found a spelling error (Tab) should be tap.
    tanner sommers - Responder
    Bei mir kommt kein troubleshoot- Modus...
    Fieps81@gmail.com
    moni R - Responder
  3. How to Reset / Restore Windows Tablet: passo 3, imagem 1 %32 How to Reset / Restore Windows Tablet: passo 3, imagem 2 %32 How to Reset / Restore Windows Tablet: passo 3, imagem 3 %32
    • Select:
    • Troubleshoot
    • Reset your PC
    Bei TrakStore ist nur “Neustarten” möglich. Das Tablet arbeitet dann aber genauso, wie als würde “Reset” angezeigt. Deutsche Spracheinstellung.
    Bernd Räker - Responder
    I want to reset the color in this tablet now please
    Edna Grimsley - Responder
    Set the color in this tablet please
    What if I get to this point and my laptop freezes and won't allow me to go any further?
    Jessica Wynn - Responder
  4. How to Reset / Restore Windows Tablet: passo 4, imagem 1 %32 How to Reset / Restore Windows Tablet: passo 4, imagem 2 %32 How to Reset / Restore Windows Tablet: passo 4, imagem 3 %32
    • Follow instructions on the screen to reset your tablet.
    I cant touch my tablet when im im this mode
    jay cee - Responder
    Did you ever get an answer to your tablet issue?
    Holly Eyerman -
    Hola, soy nuevo aqui, al intentar restaurar una tablet al llegar al “Paso 4” se quedo en la Pantalla de “Reset your Pc” y no hay forma de sacarla de ahi, me pueden apoyar, Gracias anticipadas, Soy Emilio de Cancun, Mexico
    ebcancun - Responder
    Hola, qué modelo? Tienes raton usb y adaptador OTG a mano?
    Simone - Responder
    This method didn't work it still asks for the password before allowing you to reset or restore… what else you got?
    Chris Yates - Responder
    Has anyone figured out how to get past step 4? My touchscreen wont let me select next or cancel. I've tried to use a keyboard and same results. ???????
    Holly Eyerman - Responder
    Exaxtly the same happend to me…..I-ONIK TW-8
    Geh -
    Additional free space is needed on the drive where windows is installed. Free up some space and try again.
    What should I do now please help?
    Vutivi Baloyi - Responder
    no chance to vote the bottom for fully clean, the touchscreen dosn´t do anything
    angebot12 - Responder
  5. How to Reset / Restore Windows Tablet: passo 5, imagem 1 %32 How to Reset / Restore Windows Tablet: passo 5, imagem 2 %32 How to Reset / Restore Windows Tablet: passo 5, imagem 3 %32
    • This will reset and restore your tablet to its factory settings.
    • That's all.
    • Did you do it successfully?
    Ooh! dear!!! I believe ifixit too much
    Jo Cole - Responder
    Thank you so much!! I’ve been scouring the internet trying to reset my POS Walmart tablet and this is what finally worked!
    natattack10 - Responder
    Mine seems to get stuck on step 4 I have the 2 options run and close but they are blanked out cannot go any further
    Stuart Walsh - Responder
    I am too experiencing the same problem with my Asus tablet. Have you managed to fix it? I also need help.
    Sachith Fernando -
    Me too with my acre tablet
    black mind -
    Thank youuuuuuuu so much! This thread saved my Windows 10 tablet. I was so close to giving up and selling my tablet on Ebay!!! Thank you so, sp much!
    Aricka W - Responder
    But I don't want to loose my data (like photos & other files). Please suggest.
    Akbar Ali Baig - Responder
    thanks alot is working
    Mohsin Ali - Responder
    Displayed after restarting after trouble shooting said PC was shut down incorrect and said something about firm ware and a windows kwy
    Marshall Bell - Responder
    Hi there, Can you help me to fix my tablet-pc?
    I reseted it one time but as it was supposed to install Windows, it keeps on rebooting again & again no change in the installation.
    Peter Cannon - Responder
    Wow thanks that was easy
    boricuacruz2000 - Responder
    Merci bravo à toi je suis débutant ET j'ai pourtant réussi,
    Feyzeen - Responder
    I get stuck on “additional space is needed where Windows installed.”
    E. Serrano - Responder
    I forgot my password and i reinstall new windows 10 and my touch, volume,and the camera are not working again please I need help thanks
    Maxwell Amoah - Responder
    Mine ends up with instructions warning of clearing a trust area and asks me to either press F12 or Esc or volume up and down buttons But no method for input?
    Perer O`Leary - Responder
    Thank you too :)
    ZFix -
    I cant even get it to the boot mode and I am following all the information HELP .. LEVONO 8WEE
    Pee Dee - Responder
    Merci pour tout
    Néanmoins moi j'ai tablette pc winpad 10 après réinitialisation ça s'est arrêté à 66% ce qui bloque l'allumage du tablette a nouveau.
    Comment il faut procéder pour récupérer ma tablette
    Arnaud Kantangni - Responder
    Thank you so much! Just found this in my closet and didn't know the password. Much love ifixit!
    C U - Responder
    Did not work on ROTOR tablet (without integrated keyboard) - at some point the crap tablet entered EFI shell - and does not react on external keyboard. Now - stuck in EFI shell. Only wanted to restore original windows setting, as one of the windows updates resulted in a non-working on-screen-keyboard (and also refusing external keyboard) after logging in...
    Ingo Zoller - Responder
    Not sure what the Autor means by "reset" the tablet after tapping SHIFT. My only conclusion would be to switch it off at the power button...And this does not bring me to trouble shooting mode.
    laddreyer - Responder
Conclusão
40 outras pessoas executaram este guia.
Gear Up For Future Repairs
Shop all
ZFix
Membro desde: 12/09/13
194.871 Reputação
Autoria de 330 guias
Equipe
Master Techs Membro de Master Techs
Community
327 Membros
Autoria de 1.426 guias
28Comentários do guia
Hi, did you know how to fix Windows tablet stuck in boot? It said that “no bootable device found “. Tablet brand and model : Vulcan Journey.
It started after I erase/format the tablet because I forgot the password.
Thanks
Adriane Clark - Responder
Im using a Dell and i erased like you say now im stock on boot loop.
Any solution ?
Thanks
Hjcs - Responder
Hello. I have a MPMan with Win 10 installed and the touchscreen does not work anymore.
I'm going to install win 8.1 on it .... win 8.1 was out of production. thank you very much
mircea_pricop - Responder
while i am reset final step erase everything touch not in work how to fix?
SantoshKumar subramaniyan - Responder
having same problom touch doesent qwork at reset part
lachjul -
Thanks worked a treat!
Jay Alex - Responder
iam using linx its good
Michael Shirima - Responder
I I appreciated it helps very well thanks
Goldie Mack - Responder
I get to step 4 but the buttons are blank and i can go no further
elizabethcoope33 - Responder
Hi, am using speedstar windows tablet after reseting the screen didn’t touch and windows cannot be loaded, what can i do.
ekaso
charles Ekaso - Responder
I tried it it didn't bring up the troubleshooting choice just back to enter password
bobtrem - Responder
Hello to everyone,
Me to it stock at reinstall your pc, cannot press next.
I HAVE A WINDOW DUST, DIJ4100BK132..
If anybody as a solution or another technique to do. PLEASE.
Thank you.
publicitevisuelle - Responder
I followed the instructions to restore my linx tablet to factory settings but a blue screen came up with a bar code what do i do now
robinsonjean290 - Responder
My avgo tablet has gone to auto repair and I am trying to reset it to its factory . the problem to it is that it needs to be reinstalled to its windows 10 and i bought a 32gb memory stick in order to store backup , so i can use the usb to transfer the files to my avgo. what else can i do its getting frustrated.
Iris - Responder
Hello, do u no how to reset the Tablet pc model no: "TL10IE2" Intel education solutions
oluwasusif - Responder
Merci mec du fond du coeur.???
Marco RodriG - Responder
Buongiorno ho un tablet dell' Windows ma c'è la password di un altra persona come faccio per fare un mio account nuovo
Alessio Carraresi - Responder
How do I reset the westgate resort pivot tablet? I've tried to manually hard factory reset but it still doesn't work or just freezes on the start up screen
Ally Coleman - Responder
Can not touch on Local Install or Cloud Download in Reset this PC screen.
Nam Hoang - Responder
formidable tuto, sans ça ma tablette était bonne pour la poubelle. Un grand merci.
jupafox - Responder
Formidable tuto, sans ça ma tablette était bonne pour la poubelle. Un grand merci.
jupafox - Responder
bonjour
merci pour le tuto, j etais bloqué sur un mot de passe oublié ,le votre m a permis de remettre mon petit ordi
en fonctionnement
encore merci
yannick guillot - Responder
When I reset, the device prompts "Additional free space is needed where Windows is installed. Free up some space and try again"
Any ideas on how to bypass this issue?
nyron_mohd - Responder
wow c est très magnifique
Khaled Benklila - Responder
moi ca ne fonctionne pas Lorsque je réinitialise, l'appareil affiche le message "Un espace libre supplémentaire est nécessaire là où Windows est installé. Libérez de l'espace et réessayez". on fait quoi ?
Jo a - Responder
Bonjour ma tablette c’est bloquer sur la page réinitialiser ce pc je n’arrive pas à l’éteindre tout est bloquer comment faire merci.
christelle2424 - Responder
جهازي اللوحي ينطفىء فجأة حتى وإن كان الشاحن مرتبط به ...فماهو الحل
عبدالله جمال العزيزي - Responder
Comentar
Visualizações:
Últimas 24 horas: 24
Últimos 7 dias: 215
Últimos 30 dias: 937
Ao todo: 191,435
