Ir para o conteúdo principal
How to Replace a Valve Spring on a Trumpet
Isaac Trotta
Isaac Trotta e 3 outros colaboradores
Última atualização em 22 de jul de 2015
5 minutos
Fácil
Introdução
Ir para o passo 1
This guide will teach to how to replace a spring in the valve of the trumpet.
O que você precisa
  1. How to Replace a Valve Spring on a Trumpet, valve spring: passo 1, imagem 1 %32 How to Replace a Valve Spring on a Trumpet, valve spring: passo 1, imagem 2 %32
    • To pull out the valve, first twist the top of the valve open counterclockwise to detach it from the rest of the valve.
    • Pull the valve out of the trumpet.
  2. How to Replace a Valve Spring on a Trumpet: passo 2, imagem 1 %32 How to Replace a Valve Spring on a Trumpet: passo 2, imagem 2 %32
    • Near the top of the valve, twist the top part of the screw compartment off to access the screw.
    • Pull the old spring out and replace with the new one.
    • Reassemble the valve the same way it came apart.
  3. How to Replace a Valve Spring on a Trumpet: passo 3, imagem 1 %32 How to Replace a Valve Spring on a Trumpet: passo 3, imagem 2 %32
    • Before inserting the valve back into the trumpet, put enough valve oil on the valve so that that the surface is wet, but not dripping.
    • Insert the valve into the trumpet, and screw in the top clockwise.
    • Be sure to grasp the top of the valve and twist until a clicking sound is heard and the valve locks in place to ensure that the trumpet is ready for playing.
    It won't fit in anymore
    Jerry - Responder
Conclusão
Uma outra pessoa concluiu este guia.
Gear Up For Future Repairs
Shop all
Isaac Trotta
Membro desde: 02/24/15
125 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 23-4, Green Winter 2015 Membro de Cal Poly, Team 23-4, Green Winter 2015
CPSU-GREEN-W15S23G4
7 Membros
Autoria de 15 guias
1Comentário do guia
I cannot manage to take out my valve it is so hard It’s a brand new trumpet sound like come out and then I don’t have valve oil
Flavio - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 33
Ao todo: 8,702
