Ir para o conteúdo principal
How to Replace a G-Shock GA201-1A Battery
Cordell Johnson
Cordell Johnson e 3 outros colaboradores
Última atualização em September 22, 2024
10 - 20 minutos
Fácil
Guia do aluno destaque
Introdução
Ir para o passo 1
Use this guide to replace the battery for your Casio G-Shock GA201-1A watch.
G-Shock watches are popular watches designed to resist stress, shock, water, and vibration. The lithium battery needed for this watch replacement is long-lasting, depending on the usage for the watch. Typically, the lithium battery provided in G-Shock watches lasts two to six years. The lifespan depends on how often you use the alarm or the backlight features. Frequently using either will drain the battery pretty fast and cause the need for replacement.
This guide is needed for all G-Shock owners because maintaining our watches improves the quality and experience. This brand of watches is long-lasting and durable, but it's essential to know how to take care of it in the event of overuse.
This guide will show a detailed and easy process to carefully replace the battery for this particular model. This is a user-friendly and straightforward process that anyone can accomplish to restore their watch.
Once you have completed the guide, your watch will reset. Be sure to check out the G-Shock GA201-1A user manual to properly set to the correct timezone and date.
O que você precisa
Peças
Ferramentas
Exibir mais…
A iFixit ganha comissão quando você compra por estes links.
  1. How to Replace a G-Shock GA201-1A Battery, Battery: passo 1, imagem 1 %32 How to Replace a G-Shock GA201-1A Battery, Battery: passo 1, imagem 2 %32 How to Replace a G-Shock GA201-1A Battery, Battery: passo 1, imagem 3 %32
    • Remove back cover by removing the four 6.2 mm Phillips #0 screws with the screwdriver.
    • Be careful not to lose the screws.
  2. How to Replace a G-Shock GA201-1A Battery: passo 2, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Use the tweezers to remove the rubber gasket by lifting it.
  3. How to Replace a G-Shock GA201-1A Battery: passo 3, imagem 1 %32 How to Replace a G-Shock GA201-1A Battery: passo 3, imagem 2 %32
    • Lift the white plastic covering with a pair of tweezers.
    • Be delicate; if too much force is applied, the watch's interior can pop out.
  4. How to Replace a G-Shock GA201-1A Battery: passo 4, imagem 1 %32
    • Peel off the protective sticker from the surface of the old battery.
  5. How to Replace a G-Shock GA201-1A Battery: passo 5, imagem 1 %32
    • Use tweezers to bend the metal guide away from the old battery.
  6. How to Replace a G-Shock GA201-1A Battery: passo 6, imagem 1 %32
    • Remove the old battery from the guide with tweezers.
  7. How to Replace a G-Shock GA201-1A Battery: passo 7, imagem 1 %32 How to Replace a G-Shock GA201-1A Battery: passo 7, imagem 2 %32
    • Slide the new battery into the frame and bend the metal guide onto the battery.
  8. How to Replace a G-Shock GA201-1A Battery: passo 8, imagem 1 %32 How to Replace a G-Shock GA201-1A Battery: passo 8, imagem 2 %32
    • Reset the proper time and date using the top-left "adjust" button.
    • For further instructions, consult your G-Shock GA-201 User Manual.
Conclusão
To reassemble your watch, follow these instructions in reverse order.
For optimal performance, after completing this guide, calibrate your newly installed battery.
Cordell Johnson
Membro desde: 09/28/21
157 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 7
Últimos 7 dias: 74
Últimos 30 dias: 287
Ao todo: 23,656
