Ir para o conteúdo principal
How to Replace Underside Fabric of a Chair
Nicole Keller
Nicole Keller e 3 outros colaboradores
Última atualização em August 9, 2019
15 - 20 minutos
Fácil
Introdução
Ir para o passo 1
A common problem with any armchair or sofa is that the underside upholstery fabric can begin to rip, sag, or come off entirely. This guide will provide easy instructions on how to repair the fabric in 15-20 minutes and avoid the costs of replacing the chair altogether.
O que você precisa
A iFixit ganha comissão quando você compra por estes links.
  1. How to Replace Underside Fabric of a Chair, Underside Fabric: passo 1, imagem 1 %32
    • Turn the armchair on its back.
  2. How to Replace Underside Fabric of a Chair: passo 2, imagem 1 %32
    • Use pliers to remove the staples from the chair frame.
    • If the staples are too difficult to remove, cut away the fabric with scissors.
  3. How to Replace Underside Fabric of a Chair: passo 3, imagem 1 %32
    • Measure out the dimensions of the perimeter of the chair frame.
    • Add an extra inch to each side to allow for error.
  4. How to Replace Underside Fabric of a Chair: passo 4, imagem 1 %32 How to Replace Underside Fabric of a Chair: passo 4, imagem 2 %32
    • Trace the dimensions onto the new fabric.
    • Cut along the traced lines.
  5. How to Replace Underside Fabric of a Chair: passo 5, imagem 1 %32
    • Fold under approximately a 1-inch allowance from the fabric’s edges.
    • Adjust the folded edges as needed to the correct size.
  6. How to Replace Underside Fabric of a Chair: passo 6, imagem 1 %32 How to Replace Underside Fabric of a Chair: passo 6, imagem 2 %32
    • Use a staple gun to staple the fabric to the chair frame starting at one corner.
    • If the staples do not go all the way into the chair frame, tap lightly with a hammer.
    A handy device for just this function, is a canvas stretching tool. Staple one side and use the tool to stretch tight the opposite side.
    - Normally used to tension canvas over a picture frame, and would do this job with ease.
    C McDonald - Responder
  7. How to Replace Underside Fabric of a Chair: passo 7, imagem 1 %32
    • Sit the chair upright and make sure the fabric is not visible or sagging.
    • If the fabric is visible, remove the staples from the closest corner and pull taut.
Linha de Chegada
3 outras pessoas executaram este guia.
Nicole Keller
Membro desde: 06/09/16
294 Reputação
Autoria de 1 guia
Equipe
Texas Tech, Team 3-3, Rauch SU 2016 Membro de Texas Tech, Team 3-3, Rauch SU 2016
TTU-RAUCH-SU16S3G3
2 Membros
1 Guia de autoria
2Comentários do guia
excellent ways to repair the home furniture. thanks for your ways of writing such a good article about furniture.
Nice post written by Nicole Keller.
http://www.birchi.in/kids-and-baby/kids-...
Birchi In - Responder
Thanks a lot! Wish I knew this a couple of weeks ago. Instead, I went and bought two all new 1 seater sofas in Sydney,
Lucas Bergman - Responder
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 26
Últimos 30 dias: 111
Ao todo: 24,171
