Ir para o conteúdo principal
How to Repair a Squareplug Patch Cable with SP400 Plugs
Crystal Edwards
Crystal Edwards e 2 outros colaboradores
Última atualização em March 15, 2023
5 - 10 minutos
Moderado
Introdução
Ir para o passo 1
If your Squareplug SP400 patch cable isn’t producing clear audio, use this guide to resolder the broken connections.
Patch cables, even well-soldered ones, are susceptible to stress-breaks at their connections. This is usually caused by repeated plugging/unplugging with regular use. A simple resolder with fresh wire ends and solder balls should bring the cable back to life.
Before using this guide, double-check that it’s your patch cable that is faulty. It’s possible the source of the signal loss is elsewhere in the signal chain.
O que você precisa
Ferramentas
Exibir mais…
  1. How to Repair a Squareplug Patch Cable with SP400 Plugs, Patch Cables With SP400 Plugs: passo 1, imagem 1 %32
    • Verify that the cable is faulty (unresponsive yellow and green LED indicators).
    • Yellow LED indicator
    • Green LED indicator
    • If both the yellow and green LED indicators turn on, then the cable is not the source of any audio loss. Check the pedals, amp, guitar, or power supply for issues.
    • If the red LED turns on, then the cable is shorting and will also require a resolder.
  2. How to Repair a Squareplug Patch Cable with SP400 Plugs: passo 2, imagem 1 %32
    • Unscrew the SP400 housing.
  3. How to Repair a Squareplug Patch Cable with SP400 Plugs: passo 3, imagem 1 %32 How to Repair a Squareplug Patch Cable with SP400 Plugs: passo 3, imagem 2 %32 How to Repair a Squareplug Patch Cable with SP400 Plugs: passo 3, imagem 3 %32
    • Desolder the existing solder connections.
    • Wick the existing solder completely off of the plug connections.
    • Do not touch the plug or the wick directly while desoldering.
    • For more information on soldering, check out the How to Solder and Desolder Connections guide.
  4. How to Repair a Squareplug Patch Cable with SP400 Plugs: passo 4, imagem 1 %32 How to Repair a Squareplug Patch Cable with SP400 Plugs: passo 4, imagem 2 %32
    • Cut the ends of the cable using a pair of wire cutters to expose fresh wires.
  5. How to Repair a Squareplug Patch Cable with SP400 Plugs: passo 5, imagem 1 %32 How to Repair a Squareplug Patch Cable with SP400 Plugs: passo 5, imagem 2 %32 How to Repair a Squareplug Patch Cable with SP400 Plugs: passo 5, imagem 3 %32
    • Strip the outer insulating jacket by ~1 cm.
    • The Eclipse UTP Stripper works especially well for this step.
    • Braid the ground wires.
  6. How to Repair a Squareplug Patch Cable with SP400 Plugs: passo 6, imagem 1 %32 How to Repair a Squareplug Patch Cable with SP400 Plugs: passo 6, imagem 2 %32 How to Repair a Squareplug Patch Cable with SP400 Plugs: passo 6, imagem 3 %32
    • Strip the inner insulator by ~2mm.
    • Braid the signal wires.
  7. How to Repair a Squareplug Patch Cable with SP400 Plugs: passo 7, imagem 1 %32 How to Repair a Squareplug Patch Cable with SP400 Plugs: passo 7, imagem 2 %32 How to Repair a Squareplug Patch Cable with SP400 Plugs: passo 7, imagem 3 %32
    • Tin the soldering iron tip, ground wire, signal wire, and plug connections.
    • Do not touch the plug or the solder directly while tinning.
  8. How to Repair a Squareplug Patch Cable with SP400 Plugs: passo 8, imagem 1 %32 How to Repair a Squareplug Patch Cable with SP400 Plugs: passo 8, imagem 2 %32
    • Solder the wires onto the plug connections:
    • Signal wire to the tip connection
    • Ground wire to the sleeve connection
    • The outer insulating jacket should slightly extend into the chamber of the plug to minimize cable movement.
    • Do not touch the plug directly while soldering.
  9. How to Repair a Squareplug Patch Cable with SP400 Plugs: passo 9, imagem 1 %32
    • Screw the SP400 housing.
  10. How to Repair a Squareplug Patch Cable with SP400 Plugs: passo 10, imagem 1 %32 How to Repair a Squareplug Patch Cable with SP400 Plugs: passo 10, imagem 2 %32
    • Verify that the cable is working (responsive yellow and green LED indicators).
Linha de Chegada
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 15
Ao todo: 722
