Ir para o conteúdo principal
How to Repair a Broken Slider on a Suitcase Zipper
O que você precisa
  1. How to Repair a Broken Slider on a Suitcase Zipper, Slider on a Zipper: passo 1, imagem 1 %32
    • Locate the zipper with the broken slider on the suitcase.
  2. How to Repair a Broken Slider on a Suitcase Zipper: passo 2, imagem 1 %32 How to Repair a Broken Slider on a Suitcase Zipper: passo 2, imagem 2 %32
    • Find the top of the zipper and locate the two stop pieces.
  3. How to Repair a Broken Slider on a Suitcase Zipper: passo 3, imagem 1 %32 How to Repair a Broken Slider on a Suitcase Zipper: passo 3, imagem 2 %32
    • Use your pliers to remove both of the stop pieces from the zipper.
    • Be careful to not tear the zipper fabric when removing the stop pieces.
  4. How to Repair a Broken Slider on a Suitcase Zipper: passo 4, imagem 1 %32 How to Repair a Broken Slider on a Suitcase Zipper: passo 4, imagem 2 %32 How to Repair a Broken Slider on a Suitcase Zipper: passo 4, imagem 3 %32
    • Remove the original slider from the zipper.
  5. How to Repair a Broken Slider on a Suitcase Zipper: passo 5, imagem 1 %32 How to Repair a Broken Slider on a Suitcase Zipper: passo 5, imagem 2 %32
    • Attach the new slider to the zipper.
    • You may need to use some force to get the new zipper slider onto the zipper itself.
  6. How to Repair a Broken Slider on a Suitcase Zipper: passo 6, imagem 1 %32 How to Repair a Broken Slider on a Suitcase Zipper: passo 6, imagem 2 %32 How to Repair a Broken Slider on a Suitcase Zipper: passo 6, imagem 3 %32
    • Attach two new stop pieces with a pair of pliers.
    • Use the pliers to crimp the stop pieces into the fabric.
    • The best area to place the stop pieces is directly above the first few teeth of the zipper.
  7. How to Repair a Broken Slider on a Suitcase Zipper: passo 7, imagem 1 %32 How to Repair a Broken Slider on a Suitcase Zipper: passo 7, imagem 2 %32
    • Check to make sure the zipper works by moving the slider up and down.
Linha de Chegada
Demetria
Membro desde: 03/07/19
145 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 19
Últimos 30 dias: 77
Ao todo: 1,935
