How to Remove Calcium Buildup from a Shower Head
Introdução
Ir para o passo 1It is not uncommon to have minor, or major, calcium buildup on shower heads over time. This guide will help you to safely and easily remove the calcium by using an easy homemade cleaning solution out of vinegar and water. In this guide, you will go through the steps of removing the shower head from the wall spout, making the cleaning solution, the removal of calcium from the shower head, and putting the shower head back on the wall spout.
O que você precisa
Peças
Ferramentas
Exibir mais…
Using an adjustable wrench, loosen the bolt that attaches the shower head to the wall spout by turning the wrench counterclockwise.
3 outras pessoas executaram este guia.
1Comentário do guia
How to remove rust stain (from iron) from bathroom tiles?
