Ir para o conteúdo principal
How to Reconnect the Sole of a Shoe
Cody Magnuson
Cody Magnuson e 6 outros colaboradores
Última atualização em April 29, 2022
30 minutos
Moderado
Introdução
Ir para o passo 1
This tutorial shows the general steps to take for reattaching the sole of your shoe. Before you start this repair, purchase some shoe repair glue online or from your local shoe store. You should be able to find the other materials around your house.
  1. How to Reconnect the Sole of a Shoe, How to Reconnect the Sole of a Shoe: passo 1, imagem 1 %32 How to Reconnect the Sole of a Shoe, How to Reconnect the Sole of a Shoe: passo 1, imagem 2 %32 How to Reconnect the Sole of a Shoe, How to Reconnect the Sole of a Shoe: passo 1, imagem 3 %32
    • Lay several sheets of paper towels down in order to protect the surface you are working on.
    • Take a Clorox Wipe and thoroughly clean the area where the separation has occurred.
    • Make sure the shoe is completely dry before moving to the next step
  2. How to Reconnect the Sole of a Shoe: passo 2, imagem 1 %32 How to Reconnect the Sole of a Shoe: passo 2, imagem 2 %32 How to Reconnect the Sole of a Shoe: passo 2, imagem 3 %32
    • Generously apply glue to both surfaces of the separated shoe.
    • Wait for about 2 minutes to allow the glue to set before reconnecting the sole.
    • Make sure that glue is applied to every surface that is being reconnected
    • When the glue application is done, press and hold the sole and the separated surface together in order for the glue to dry.
  3. How to Reconnect the Sole of a Shoe: passo 3, imagem 1 %32
    • Clean up any excess glue that has oozed out of the split with a Clorox Wipe.
    • Removing glue is much easier when it is still wet. If some glue oozes out during the drying process, it can still be removed yet it will be more difficult.
  4. How to Reconnect the Sole of a Shoe: passo 4, imagem 1 %32 How to Reconnect the Sole of a Shoe: passo 4, imagem 2 %32
    • Stuff an object, such as a 1/2 filled water bottle or newspaper, into the shoe to keep its form.
    • Stack heavy objects on top of the part of the shoe that is being reconnected.
    • The sole of the shoe may shift when stacking the weight. Make sure the sole is inline with the shoe.
    • Due to the shoe's curvature, I had to place an object under the heal of the shoe to get the desired contact.
  5. How to Reconnect the Sole of a Shoe: passo 5, imagem 1 %32 How to Reconnect the Sole of a Shoe: passo 5, imagem 2 %32
    • Remove any excess glue with a Wet rag or moist towelette.
    • In order to remove the dried glue, you may need to apply a lot of pressure and scrub rigorously.
    • The shoe is now fixed and ready to use.
    How long does it take for the glue to dry completely?
    salt bowl - Responder
    Funny that the shoe you're fixing is a Converse. That's the shoe I'm fixing too. This is the first time I've ever had this kind of separation on a shoe!
    The Prowitz Project - Responder
Conclusão
9 outras pessoas executaram este guia.
Cody Magnuson
Membro desde: 02/23/15
555 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 12-2, Green Winter 2015 Membro de Cal Poly, Team 12-2, Green Winter 2015
CPSU-GREEN-W15S12G2
6 Membros
Autoria de 14 guias
4Comentários do guia
What glue do you use
lizasutton1997 - Responder
Inexpensive glue called “Shoe goo”.
J. J -
What would you do if you don't have any type of glue?
Your Mum - Responder
Go out and buy some.
pretoast -
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 99
Últimos 30 dias: 301
Ao todo: 44,328
