Ir para o conteúdo principal
How to Reattach the Cap on an iFixit Precision Bit Driver
Kyle Smith
Kyle Smith e um outro colaborador
Última atualização em September 26, 2024
5 - 10 minutos
Fácil
Introdução
Ir para o passo 1
Follow this guide to reattach the blue cap on an iFixit Precision Bit Driver. You may need to do this repair if the cap has fallen out of the bit driver.
You can always contact our customer service team if you would like to replace your broken Precision Bit Driver.
  1. How to Reattach the Cap on an iFixit Precision Bit Driver, Cut a piece of floss: passo 1, imagem 1 %32 How to Reattach the Cap on an iFixit Precision Bit Driver, Cut a piece of floss: passo 1, imagem 2 %32
    • Cut an approximately six-inch piece of waxed dental floss.
  2. How to Reattach the Cap on an iFixit Precision Bit Driver, Wrap the floss around the post: passo 2, imagem 1 %32 How to Reattach the Cap on an iFixit Precision Bit Driver, Wrap the floss around the post: passo 2, imagem 2 %32 How to Reattach the Cap on an iFixit Precision Bit Driver, Wrap the floss around the post: passo 2, imagem 3 %32
    • The blue cap is secured to the bit driver by a threaded post that screws into the bit driver's upper body.
    • The threaded post can't be screwed into the upper body by twisting the cap because the cap spins freely around the post. Instead, you'll need to hold the post still so the upper body can be screwed on.
    • Hold one end of the floss against the side of the cap.
    • Wrap the middle of the floss twice around the widest part of the post (below the rubber o-ring).
    • Don't tie the floss into a knot as this will prevent you from removing the floss after the upper body has been screwed on to the threaded post.
  3. How to Reattach the Cap on an iFixit Precision Bit Driver, Tighten the floss: passo 3, imagem 1 %32 How to Reattach the Cap on an iFixit Precision Bit Driver, Tighten the floss: passo 3, imagem 2 %32
    • Pull the two ends of the floss tight to create a secure hold on the post.
  4. How to Reattach the Cap on an iFixit Precision Bit Driver, Arrange and hold the ends of the floss: passo 4, imagem 1 %32 How to Reattach the Cap on an iFixit Precision Bit Driver, Arrange and hold the ends of the floss: passo 4, imagem 2 %32 How to Reattach the Cap on an iFixit Precision Bit Driver, Arrange and hold the ends of the floss: passo 4, imagem 3 %32
    • Arrange the ends of the floss so that they hang down over the edge of the cap on the opposite side that they crossed on the post.
    • Press the ends of the floss against the side of the cap to prevent the post from spinning.
  5. How to Reattach the Cap on an iFixit Precision Bit Driver, Optional threadlocker information: passo 5, imagem 1 %32
    • You can optionally apply a threadlocker (such as Loctite Threadlocker Blue 242) to secure the threaded post to the upper body.
    • Put on your protective gloves and safety glasses while applying the threadlocker.
    • Clean the threaded post and the upper body's screw hole with a lint-free cloth.
    • Apply one to two drops of threadlocker to the threaded post.
    • Make sure you don't get threadlocker on any other part of the cap. Doing so may prevent the cap from spinning. You only need to apply enough for an even spread on the threaded post.
    • After screwing the upper body on to the threaded post, wait for the recommended cure time before using the bit driver.
  6. How to Reattach the Cap on an iFixit Precision Bit Driver, Screw the upper body on to the post: passo 6, imagem 1 %32 How to Reattach the Cap on an iFixit Precision Bit Driver, Screw the upper body on to the post: passo 6, imagem 2 %32
    • Insert the threaded post into the upper body's screw hole.
  7. How to Reattach the Cap on an iFixit Precision Bit Driver: passo 7, imagem 1 %32 How to Reattach the Cap on an iFixit Precision Bit Driver: passo 7, imagem 2 %32 How to Reattach the Cap on an iFixit Precision Bit Driver: passo 7, imagem 3 %32
    • Screw the upper body of the bit driver clockwise on to the threaded post until it is finger-tight.
    • The ends of the floss will rotate clockwise when the upper body is almost fully screwed on. Continue to screw the upper body for about half a turn after this occurs to screw it on completely.
  8. How to Reattach the Cap on an iFixit Precision Bit Driver, Remove the floss: passo 8, imagem 1 %32 How to Reattach the Cap on an iFixit Precision Bit Driver, Remove the floss: passo 8, imagem 2 %32 How to Reattach the Cap on an iFixit Precision Bit Driver, Remove the floss: passo 8, imagem 3 %32
    • Pull and rotate one end of the floss around the post twice in the opposite direction that it was wrapped.
  9. How to Reattach the Cap on an iFixit Precision Bit Driver: passo 9, imagem 1 %32
    • Pull and remove the floss from the bit driver.
    • If the floss is difficult to remove, try pulling on the other end. You can hold the gap between the cap and the bit driver at eye level to see if the floss is still looped around the post.
Conclusão
Repair didn’t go as planned? Ask our iFixit Precision Bit Driver Answers community for help.
15 outras pessoas executaram este guia.
Kyle Smith
Membro desde: 02/01/21
45.324 Reputação
Autoria de 123 guias
8Comentários do guia
Thanks for this information. I was worried about this but now I am Happy.
Saddaf Khan - Responder
Well that’s interesting. My blue cap popped off the screw. I had to use superglue… :-\
Ryan Coleman - Responder
Ok this is an epic repairability and culture standard that is demonstrated with this article - posting instructions on how to repair your own products! I wish this kind of attitude would spread in all tech industries.
I run a small tech startup myself, and this article just inspired me to do the same for the products we develop
Ignas Kaz - Responder
Great this was the only thing talkative annoyed my about this set. Now I can fixit brilliant.. had a few do it in the past ones at my work and ones I use on my youtube channel.. but would not use or recommend any other tools.
Neil - Responder
Comentar
Visualizações:
Últimas 24 horas: 31
Últimos 7 dias: 138
Últimos 30 dias: 1,011
Ao todo: 18,417
