Ir para o conteúdo principal
How to Prevent Wheel Bite
Jared Stine
Jared Stine e 7 outros colaboradores
Última atualização em 31 de jul de 2019
10 - 15 minutos
Fácil
Pré-requisitos ausentes
Introdução
Ir para o passo 1
There are a number of ways that you can reduce the occurrence of wheel bite with your skateboard. All of these ways can be used separately or together depending on your preference and need. This guide will show you how to perform the three most fundamental methods in order of how they would be installed together. Keep in mind you can pick and choose any of these methods at your discretion.
O que você precisa
Ferramentas
  1. How to Prevent Wheel Bite, How to Prevent Wheel Bite: passo 1, imagem 1 %32
    • When it comes to preventing wheel bite you may want to add a riser. This will occur during the truck installation process. If you have not started this process, get to step 3 in the Truck Installation guide and return here for your next step.
    • Now that you are just about ready to install your trucks, simply place the riser onto the hardware before the trucks. Return to the Truck Installation guide to finish installing the trucks.
  2. How to Prevent Wheel Bite: passo 2, imagem 1 %32
    • Once you have installed your trucks you can tighten your kingpin nut using a 9/16" wrench to prevent wheel bite.
    • Tightening your kingpin will limit your turning ability so that the wheels won't catch on the deck.
  3. How to Prevent Wheel Bite: passo 3, imagem 1 %32
    • Another way to further prevent wheel bite is to replace the kingpin bushings with a harder ones. You will first want to remove the kingpin nut completely using your 9/16" wrench.
  4. How to Prevent Wheel Bite: passo 4, imagem 1 %32
    • Remove the kingpin bushings from the kingpin.
  5. How to Prevent Wheel Bite: passo 5, imagem 1 %32
    • Slide on your new harder kingpin bushings.
  6. How to Prevent Wheel Bite: passo 6, imagem 1 %32
    • Place the washer back over your new kingpin bushing and thread on the kingpin nut to your preferred tightness. This harder bushing will make it harder to turn, preventing the wheels from hitting the deck on hard turns.
Conclusão
To remove your risers, simply remove your trucks following the reverse directions of the Truck Installation guide. Follow steps of this guide in reverse to replace your old kingpin bushing.
5 outras pessoas executaram este guia.
Gear Up For Future Repairs
Shop all
Jared Stine
Membro desde: 10/05/12
800 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 6-32, Regan Fall 2012 Membro de Cal Poly, Team 6-32, Regan Fall 2012
CPSU-REGAN-F12S6G32
5 Membros
Autoria de 6 guias
1Comentário do guia
That's some mondo wheel bite on that board! :-P
Wesley Applequist - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 24
Ao todo: 18,921
