Ir para o conteúdo principal
How to Open the Fitbit Charge 2
Adriana Zwink
Adriana Zwink e um outro colaborador
Última atualização em May 24, 2024
10 - 15 minutos
Moderado
Introdução
Ir para o passo 1
Use this guide to open your Fitbit Charge 2 for repairs.
O que você precisa
Ferramentas
  • iOpener
    iOpener
  • iSesamo Opening Tool
  • Spudger
    Spudger
Exibir mais…
  1. How to Open the Fitbit Charge 2, Remove the watch band: passo 1, imagem 1 %32
    • Before starting, take your Fitbit Charge 2 off the charger and power it down.
    • Remove the watch band on both sides.
  2. How to Open the Fitbit Charge 2, Heat the touch screen: passo 2, imagem 1 %32
    • Heat an iOpener and apply it to the touch screen for two minutes.
    • The screen is not glued down, but the heat helps to loosen the touch screen assemly.
  3. How to Open the Fitbit Charge 2, Slide along the left edge: passo 3, imagem 1 %32 How to Open the Fitbit Charge 2, Slide along the left edge: passo 3, imagem 2 %32 How to Open the Fitbit Charge 2, Slide along the left edge: passo 3, imagem 3 %32
    Ferramenta utilizada neste passo:
    $9.99
    • Insert an iSesamo into the gap between the touch screen and the watch assembly on the top left corner.
    • Slide the iSesamo along the left edge to the bottom left corner.
  4. How to Open the Fitbit Charge 2, Slide along the bottom edge: passo 4, imagem 1 %32 How to Open the Fitbit Charge 2, Slide along the bottom edge: passo 4, imagem 2 %32
    • Slide the iSesamo around the bottom left corner.
    • Slide it along the edge to the bottom right corner.
  5. How to Open the Fitbit Charge 2: passo 5, imagem 1 %32 How to Open the Fitbit Charge 2: passo 5, imagem 2 %32 How to Open the Fitbit Charge 2: passo 5, imagem 3 %32
    • Slide the iSesamo around the bottom right corner.
    • Keep sliding it along the right edge to the top right corner.
  6. How to Open the Fitbit Charge 2: passo 6, imagem 1 %32 How to Open the Fitbit Charge 2: passo 6, imagem 2 %32
    • Slide the iSesamo around the top right corner.
    • Slide it along the top edge to the top left corner.
  7. How to Open the Fitbit Charge 2: passo 7, imagem 1 %32 How to Open the Fitbit Charge 2: passo 7, imagem 2 %32
    • Place the iSesamo under the top left corner.
    • Feel free to reattach the watch band for this and the next step for a better grip.
    • Pry up the touch screen assembly by twisting the iSesamo sideways to create a gap and unhinge the plastic clips which are holding the screen in place.
  8. How to Open the Fitbit Charge 2: passo 8, imagem 1 %32 How to Open the Fitbit Charge 2: passo 8, imagem 2 %32
    • Place the iSesamo under the top right corner.
    • Pry up the touch screen assembly by twisting the iSesamo sideways to create a gap.
  9. How to Open the Fitbit Charge 2: passo 9, imagem 1 %32 How to Open the Fitbit Charge 2: passo 9, imagem 2 %32
    • Insert a spudger into the gap on the top edge of your Fitbit Charge 2.
    • Use the spudger to pry up the touch screen assembly.
    • Do not remove the touch screen assembly all the way yet—it's still connected to the motherboard.
  10. How to Open the Fitbit Charge 2: passo 10, imagem 1 %32
    • Carefully fold the touch screen assembly in the direction of the bottom edge.
Conclusão
Opening didn’t go as planned? Ask our Answers community for help.
Adriana Zwink
Membro desde: 12/18/19
56.951 Reputação
Autoria de 167 guias
Equipe
iFixit Membro de iFixit
Staff
121 Membros
Autoria de 19.845 guias
1Comentário do guia
How do I get the daughterboard out?
Pospesel - Responder
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 7
Últimos 30 dias: 66
Ao todo: 5,973
