Ir para o conteúdo principal
How to Force Restart the Samsung Galaxy Watch
Tobias Isakeit
Tobias Isakeit
Última atualização em July 10, 2024
10 - 15 segundos
Muito fácil
Introdução
Ir para o passo 1
Use this guide to force restart your Samsung Galaxy Watch.
  1. How to Force Restart the Samsung Galaxy Watch, How to Force Restart the Samsung Galaxy Watch: passo 1, imagem 1 %32
    • Push and hold the lower button for at least 7 seconds.
    • Let go of the button when you see the watch restart.
    My smart watch got problem with cant power on
    kok chua - Responder
    me too. I have charged and tried to restart by power button down but hasn't come back on. Any other ideas?
    PJ Cav - Responder
    Hola, si mantenéis pulsado el botón de encendido hasta que salga rebooting. En ese momento pulsar repetidamente el botón de encendido hasta que salga la opción de recovery y pulsais nuevamente el boton de encendido 1 o 2 segundos para seleccionarlo.
    Fernando Rivero - Responder
    J'ai réinitialiser ma montre touche retour en arrière ne fonctionne pas
    NADIR BENMAMAR - Responder
Linha de Chegada
6 outras pessoas executaram este guia.
Tobias Isakeit
Membro desde: 03/31/14
124.932 Reputação
Autoria de 189 guias
Equipe
14Comentários do guia
If I have done the hold button 7 seconds & it still dont come on then what?
Tracy L - Responder
That's what I want to know also
paullawrence657 - Responder
Me too. My watch won't come on either.
Sheri Hall Lee - Responder
I suppose all commenters above have tried to charge the watch over night to make sure the battery is not completely depleted.
You could try and restart WHILE it is charging or even just placed on the charger without being plugged into the wall.
Tobias Isakeit - Responder
I dropped my watch off the counter and it's just keeps showing rebooting it won't let me restart watch or activate it from my phone.
Bailey Nasuta - Responder
Did you check if maybe the button is stuck and forces it to restart?
Tobias Isakeit -
I've tried multiple rebooting techniques and none have worked, I also went into galaxy wearable app on phone to reset but it won't let me into general settings to do reset, the app also tells me it's not connected but how am I to connect if it don't turn on?
J LETICIA - Responder
im having the exact same issues, nothing is working
Vince Blagdon - Responder
Mine is having the same issue. After swimming it did not shut off the water mode, no matter what. Tried to reset it but the power button did not work. Have opened it to look inside and try to find something easy to fix but it´s hard to find the faulty part/component. So, without knowing which spare part to buy and replace it I guess it´s end of game for this piece of hardware. Not worth it taking to servicing since spare parts for this 5 years old watch are not easily available and/or might be as expensive as new watch.
zapata el loko - Responder
Not restart my watch
Ganesh Chettri - Responder
battery replacement possible, if yes where can I got the battery
Arron Fu - Responder
Hola mi Samsung whatch 6 aparece idioma,ayuda,accesibilidad y no sale de ahí ya lo reinicie y lo apagué 😔. O sale no sé qué hacer ayuda
Yesika Duran - Responder
Comentar
Visualizações:
Últimas 24 horas: 20
Últimos 7 dias: 123
Últimos 30 dias: 468
Ao todo: 47,465
