Ir para o conteúdo principal
How to Fix a Noisy Table Fan
Codi Barnett
Codi Barnett e 4 outros colaboradores
Última atualização em June 25, 2022
10 - 15 minutos
Muito fácil
Introdução
Ir para o passo 1
Through continued use, table fans tend to collect dust and debris. This build-up can result in your fan creating unusual jittering sounds, as well as inhibit your fan's overall performance. Fortunately, this fix is relatively simple, and doesn't even require a screwdriver--all you need is a damp washcloth and your own two hands.
Please note: While it's common for debris to be the source of this problem, it is possible that this isn't the case, and that another part of the fan (such as its motor) is at fault. This is beyond what is covered in this guide, so if your fan is still making noises after proper cleaning, you may have to look elsewhere for a different fix approach.
O que você precisa
A iFixit ganha comissão quando você compra por estes links.
  1. How to Fix a Noisy Table Fan, How to Fix a Noisy Table Fan: passo 1, imagem 1 %32 How to Fix a Noisy Table Fan, How to Fix a Noisy Table Fan: passo 1, imagem 2 %32
    • Before starting the fix, be sure to turn off and unplug the fan.
    • Place your fan on a clear, open level area, like a table top.
    • It may help to place a towel underneath the fan, as it will catch some of the falling debris.
  2. How to Fix a Noisy Table Fan: passo 2, imagem 1 %32 How to Fix a Noisy Table Fan: passo 2, imagem 2 %32 How to Fix a Noisy Table Fan: passo 2, imagem 3 %32
    • Remove the clamps surrounding the protective cage by pulling each outward (away from the fan) one at a time.
    • Though this may require some force, don't pull on the clamps too hard, as they can be easily broken.
    • As you are removing the last few clamps, be sure to hold the cage with another hand. Otherwise, it will fall right off!
    • Once the front end of the cage is free, remove it from the fan and place it to the side for now.
  3. How to Fix a Noisy Table Fan: passo 3, imagem 1 %32 How to Fix a Noisy Table Fan: passo 3, imagem 2 %32 How to Fix a Noisy Table Fan: passo 3, imagem 3 %32
    • Now that the blades are exposed, it's time to remove them. Holding the blade piece in place with another hand, twist off the knob in the center of the piece.
    • Take note of the direction that you should be spinning the knob for loosening, which is labeled as clockwise on this fan (not lefty-loosy!) If you're having trouble twisting the knob off, you may be twisting it the wrong way!
    • Once loosend enough, the knob should spin right off.
  4. How to Fix a Noisy Table Fan: passo 4, imagem 1 %32 How to Fix a Noisy Table Fan: passo 4, imagem 2 %32
    • With the knob removed, these blades can come off!
    • Pull the blade piece straight off the rotor, using your other arm to weigh down the rest of the fan.
    • Set the blade piece to the side alongside the first half of the cage.
    My fan is brand new and vibrates off the counter. Help!
    Dolores Albert - Responder
  5. How to Fix a Noisy Table Fan: passo 5, imagem 1 %32 How to Fix a Noisy Table Fan: passo 5, imagem 2 %32 How to Fix a Noisy Table Fan: passo 5, imagem 3 %32
    • Now to remove the second half of the cage. Do this by first removing the knob surrounding the rotor.
    • Like the first knob, be sure to check for the labelings to see which direction you should be turning. On this fan, I have to twist counter-clockwise this time (this time, lefty-loosy!).
  6. How to Fix a Noisy Table Fan: passo 6, imagem 1 %32 How to Fix a Noisy Table Fan: passo 6, imagem 2 %32 How to Fix a Noisy Table Fan: passo 6, imagem 3 %32
    • With this knob off, you can now slide the other half of the cage off.
    • When reassembling the fan, remember to slide this half of the cage back on by aligning the holes in the metal center of the cage with the stumps sticking out on the fan.
    • With all the easily-detachable parts of the fan off, you should now be left with a bare fan.
  7. How to Fix a Noisy Table Fan: passo 7, imagem 1 %32 How to Fix a Noisy Table Fan: passo 7, imagem 2 %32 How to Fix a Noisy Table Fan: passo 7, imagem 3 %32
    • Time to get down to cleaning! First, the fan blades. Do not immerse the fan in water and never allow water to drip into the motor housing.
    • Dampen your wash cloth with warm water and begin wiping down the surface of the blades. Never use gasoline, benzene, or thinner to clean the fan. This will damage the surface of the fan.
    • Be sure to clean all the nooks and crannies. Let the piece dry.
  8. How to Fix a Noisy Table Fan: passo 8, imagem 1 %32 How to Fix a Noisy Table Fan: passo 8, imagem 2 %32
    • Next, the protective cage.
    • This procedure is similar to that for cleaning the blades: use your dampened cloth to wipe down both sides of each cage.
  9. How to Fix a Noisy Table Fan: passo 9, imagem 1 %32 How to Fix a Noisy Table Fan: passo 9, imagem 2 %32
    • Finally, the rest of the fan.
    • Like in the last two steps, wipe down the rotor and the area surrounding it on the fan. After cleaning, be sure to completely dry the fan with a cloth or towel before using it.
    • For further cleaning, spray compressed air into the fan to help free the area surrounding the motor of debris and thus improve the longevity of the fan.
    • Voila! Your fan should be (almost) as good as new! Be sure to repeat this often for proper fan maintenance (once every one or two weeks should suffice, depending on your fan usage).
    Mine case is quite a different root cause for humming noise. Only when clearing of four roller’s surface of underneath baseplate, the noise disappeared. Slight un-evenness of the whole platform had creat humming problem.
    Vincent Maung - Responder
    LOL, clean a fan every 2 weeks? I clean ours about every 2 to 3 years. My proplem is the fan rattles when tilted upwards. It's a 16 inch desktop fan, but it sits on the floor in our bedroom. I know it is the motor shaft shifting back and forth. This fan has done this pretty much since it was new. Is there any way to put a spring or something on the motor shaft to stop this rattling?
    John Wente - Responder
    Not helpful. Title says how to fix a noisy fan not a dirty fan!!!!!
    Debbie Higgins Baumann - Responder
    If you read the introduction, the author of the article explains that dirt and debris could be one of the causes of a noisy fan, but it does not necessarily apply to all cases. If you tried cleaning the fan and had no success in fixing the issue, there's a whole device page dedicated to fans if you head over to: Household Fan which may point you to the right solution, you may also try asking on the answers forum (https://www.ifixit.com/Answers/Ask/Fan) and there's a very good chance an experienced user can guide you through the process of IDing and fixing the problem
    Simone -
    Simone - Responder
Conclusão
Note: It may be easier to reassemble your fan with it lying down with the rotor facing up, as it allows gravity to hold certain pieces in place for you.
22 outras pessoas executaram este guia.
Codi Barnett
Membro desde: 09/29/15
761 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 15-5, Green Fall 2015 Membro de Cal Poly, Team 15-5, Green Fall 2015
CPSU-GREEN-F15S15G5
4 Membros
Autoria de 14 guias
10Comentários do guia
Worked like a charm. I had a noisy pedestal fan in my bedroom that's only used during the summer, but it got noisy enough to wake us up. Now it's nice and quiet. I also made a cover for it to keep the dust out when it's being stored during winter. Our fan had the directions that the various pieces were to be turned to tighten them imprinted on the pieces themselves. It's an 18-year-old Lasko pedestal fan, and I'd cleaned it before, but not as thoroughly as the instructions indicated.
vegakitty - Responder
my fan is brand new.it makes a creeky squeeky sound every time it turns to the right.i know how to put a fan together,but i've never tried to see if i can open up a motor to see if i can hear where it is originating from.i think the joint is too tight in the arm maybe.i can't find anyone who knows who can fix it-no electrician knows.i also have problem finding someone who can install an apartment ac,for when i need a new ac-no ac business has a clue!
natalie charney - Responder
My fan seems like it has lost it's balance....it makes ticking sound while rotating.... Seems like it's neck is broken... What should I do...???
Priyanka - Responder
First Go to the old things man with Ur f***Kng fan n sell them after that u buy a new fan…teky
Kiran Darling Jain -
wow !!! it is nice article about learning how to fix a noisy table fan.
Medcard Now - Responder
This article could have been written in 2 words: “Clean it”
Marcus - Responder
Cleaning the fan (which isn't fixing it) did nothing.
The fan required some lubricant on the spindle, which was worked into the other areas at either end.
After a moment's, the fan was more quiet than before.
Peter Austin - Responder
my fan is brand new, bought it and it sat for around 4 months doing nothing, i took it plugged it in and it worked fine then after 10 minutes it started making very loud and noisy buzzing noise i couldnt sleep at all..
Dylan the77villan - Responder
Should I oil it after cleaning.
Terry Grasdal - Responder
One thing to add... check for long hair tightly wrapped around the fan blade stem. My fan sucked in a few long hairs from my bedroom and once I removed those with tweezers, the fan was perfect.
Diane D - Responder
Comentar
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 65
Últimos 30 dias: 325
Ao todo: 206,875
