Ir para o conteúdo principal
How to Fix a Brazilian Hammock
Desiree Galvan
Desiree Galvan e um outro colaborador
Última atualização em December 26, 2023
30 minutos - 1 hora
Moderada
In this guide you will find the steps to repair a Brazilian Hammock. The purpose of this guide is to restore the durability of the hammock by sewing on a patch. The guide demonstrates the repair using hand stitching.
If you would like to reinforce the rip before placing the patching and have access to a sewing machine, follow this guide for creating a Zig Zag Patch. After creating the zig zag patch, place the fabric patch over it for a smoother feel and nicer appearance. We also recommend reinforcing the rip on both sides of the hammock.
  1. How to Fix a Brazilian Hammock, How to Fix a Brazilian Hammock: passo 1, imagem 1 %32
    • Place the hammock on a flat surface.
    • Use scissors to cut the frayed ends from the damaged area.
  2. How to Fix a Brazilian Hammock: passo 2, imagem 1 %32 How to Fix a Brazilian Hammock: passo 2, imagem 2 %32
    • Align both sides of the tear leaving a quarter-inch gap between both sides of the tear.
    • Use safety pins to temporarily hold both sides of the tear together.
  3. How to Fix a Brazilian Hammock: passo 3, imagem 1 %32
    • Cut a patch of the Ripstop fabric slightly larger than the tear.
  4. How to Fix a Brazilian Hammock: passo 4, imagem 1 %32
    • Place the fabric on top of the tear and using safety pins temporarily hold the fabric to the hammock.
  5. How to Fix a Brazilian Hammock: passo 5, imagem 1 %32 How to Fix a Brazilian Hammock: passo 5, imagem 2 %32 How to Fix a Brazilian Hammock: passo 5, imagem 3 %32
    • Be careful with the sewing needle. The end is very sharp.
    • Thread the needle and tie a knot at the end.
  6. How to Fix a Brazilian Hammock: passo 6, imagem 1 %32 How to Fix a Brazilian Hammock: passo 6, imagem 2 %32 How to Fix a Brazilian Hammock: passo 6, imagem 3 %32
    • This step requires basic sewing skills but is easy to accomplish with time.
    • Use the threaded needle to sew from the bottom of the patch up and around the perimeter.
    • Make sure the needle and thread go through the patch and existing hammock material.
  7. How to Fix a Brazilian Hammock: passo 7, imagem 1 %32
    • When finished tie a knot at the end of the stitch.
    • Make sure the knot is large enough, so it does not slip through the stitches.
  8. How to Fix a Brazilian Hammock: passo 8, imagem 1 %32 How to Fix a Brazilian Hammock: passo 8, imagem 2 %32
    • Remove all the safety pins and appreciate your work.
Conclusão
This guide is now completed, enjoy your newly restored hammock.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 151
