Ir para o conteúdo principal
Zig-zag Patch
O que você precisa
    1. Zig-zag Patch, Zig-zag Patch: passo 1, imagem 1 %32 Zig-zag Patch, Zig-zag Patch: passo 1, imagem 2 %32 Zig-zag Patch, Zig-zag Patch: passo 1, imagem 3 %32
      • Examine the damage. Clip any long, loose threads, and remove any debris from the hole.
      • Measure the length and width of the hole.
      • In our case it looks like 2" by 1".
      Pergunte ao FixBot
      Comentar
    2. Zig-zag Patch: passo 2, imagem 1 %32 Zig-zag Patch: passo 2, imagem 2 %32 Zig-zag Patch: passo 2, imagem 3 %32
      • Grab a scrap of denim or other heavy-weight fabric and mark your measurements plus one inch in each direction.
      • In our case it will be 3" by 2".
      • Cut the scrap into a rectangle the dimensions of your new measurements.
      Pergunte ao FixBot
      Comentar
    3. Zig-zag Patch: passo 3, imagem 1 %32 Zig-zag Patch: passo 3, imagem 2 %32
      • Insert the rectangle of fabric into the jean leg and position it under the hole.
      • Be sure that you put the rectangle of fabric in the pant leg and not behind it—you only want to work on one layer of fabric.
      Pergunte ao FixBot
      Comentar
    4. Zig-zag Patch: passo 4, imagem 1 %32 Zig-zag Patch: passo 4, imagem 2 %32 Zig-zag Patch: passo 4, imagem 3 %32
      • Thread your sewing machine with your desired thread color.
      • Slide the pant leg onto the arm of the sewing machine.
      • You may need to remove the sewing machine table for the pant leg to fit over the arm.
      • Be sure that the pant leg is around the arm of the sewing machine. If both layers are stacked on one another, you will sew the pant leg shut.
      Pergunte ao FixBot
      Comentar
    5. Zig-zag Patch: passo 5, imagem 1 %32 Zig-zag Patch: passo 5, imagem 2 %32 Zig-zag Patch: passo 5, imagem 3 %32
      • Check that the rectangle of fabric is still laying flat, centered beneath the hole.
      • Lower the pressor foot.
      • Sew a straight line over the hole going about five stitches past the damage.
      Pergunte ao FixBot
      Comentar
    6. Zig-zag Patch: passo 6, imagem 1 %32 Zig-zag Patch: passo 6, imagem 2 %32 Zig-zag Patch: passo 6, imagem 3 %32
      • Lift the pressor foot.
      • Rotate the jean leg a few degrees toward the center of the hole.
      • Engage the backstitch function on your sewing machine, and sew a straight line back over the hole, going about five stitches beyond the damage.
      Pergunte ao FixBot
      Comentar
    7. Zig-zag Patch: passo 7, imagem 1 %32 Zig-zag Patch: passo 7, imagem 2 %32 Zig-zag Patch: passo 7, imagem 3 %32
      • Repeat steps five and six, continuing to rotate and sew lines of stitching back and forth until you cover the entire hole.
      Pergunte ao FixBot
      Comentar
    8. Zig-zag Patch: passo 8, imagem 1 %32 Zig-zag Patch: passo 8, imagem 2 %32
      • When you are satisfied with your stitching, backstitch two or three stitches.
      • Lift the needle and pressor foot.
      • Slide the jean leg off of the sewing machine.
      Pergunte ao FixBot
      Comentar
    9. Zig-zag Patch: passo 9, imagem 1 %32 Zig-zag Patch: passo 9, imagem 2 %32
      • Clip any dangling threads and admire your work.
      Pergunte ao FixBot
      Comentar
    10. Zig-zag Patch: passo 10, imagem 1 %32 Zig-zag Patch: passo 10, imagem 2 %32 Zig-zag Patch: passo 10, imagem 3 %32
      • Still not satisfied? Alrighty, let's add some decorative stitching the other way.
      • This is completely optional. If you are happy with your work, you can stop here.
      • Slide the pant leg back onto the arm of the sewing machine, making sure that the leg goes around the arm.
      Pergunte ao FixBot
      Comentar
    11. Zig-zag Patch: passo 11, imagem 1 %32 Zig-zag Patch: passo 11, imagem 2 %32
      • Carefully rotate the jean leg 90 degrees.
      • Be sure that there is only one layer of fabric (plus the rectangle) between the sewing machine and the needle, or else you will sew the pant leg shut.
      Pergunte ao FixBot
      Comentar
    12. Zig-zag Patch: passo 12, imagem 1 %32 Zig-zag Patch: passo 12, imagem 2 %32
      • Sew a straight line of stitching over the damaged area.
      Pergunte ao FixBot
      Comentar
    13. Zig-zag Patch: passo 13, imagem 1 %32 Zig-zag Patch: passo 13, imagem 2 %32 Zig-zag Patch: passo 13, imagem 3 %32
      • Just like before, at the end of each line of stitching, lift the pressor foot, rotate the jeans a few degrees, and sew another line of stitching.
      • When you are happy with the way that the stitching looks, backstitch two or three stitches.
      Pergunte ao FixBot
      Comentar
    14. Zig-zag Patch: passo 14, imagem 1 %32 Zig-zag Patch: passo 14, imagem 2 %32
      • Lift the pressor foot and needle.
      • Slide the pant leg off the arm of the sewing machine.
      Pergunte ao FixBot
      Comentar
    15. Zig-zag Patch: passo 15, imagem 1 %32 Zig-zag Patch: passo 15, imagem 2 %32
      • Clip any dangling threads.
      Pergunte ao FixBot
      Comentar
Conclusão
Ta-da! Nice work.
8 outras pessoas executaram este guia.
Brittany McCrigler
Membro desde: 03/05/12
91.006 Reputação
Autoria de 142 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 51.066 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 9
Últimos 7 dias: 61
Últimos 30 dias: 317
Ao todo: 39,767
