Ir para o conteúdo principal
How to Downsize Jeans Without Sewing
O que você precisa
  1. How to Downsize Jeans Without Sewing, How to Downsize Jeans Without Sewing: passo 1, imagem 1 %32
    • While wearing the jeans, pinch the excess fabric at the center of the backside of the waistband.
    • Ironing to remove jeans of all wrinkles can help measure the alteration more accurately.
  2. How to Downsize Jeans Without Sewing: passo 2, imagem 1 %32
    • Keeping the excess fabric pinched, place two highlighter marks at the point where you with the waist to touch.
    • Once done, remove the jeans and lay them flat with the front side up.
  3. How to Downsize Jeans Without Sewing: passo 3, imagem 1 %32 How to Downsize Jeans Without Sewing: passo 3, imagem 2 %32
    • Locate the points on the seam directly below the two highlighter marks.
    • Using the seam ripper or a pair of scissors, break the two seams to loosen the lining along the fabric.
  4. How to Downsize Jeans Without Sewing: passo 4, imagem 1 %32 How to Downsize Jeans Without Sewing: passo 4, imagem 2 %32 How to Downsize Jeans Without Sewing: passo 4, imagem 3 %32
    • Starting from where one of the seams is broken, cut up the waistband, stopping just before reaching the top.
    • Repeat this process for the other broken seam point.
  5. How to Downsize Jeans Without Sewing: passo 5, imagem 1 %32 How to Downsize Jeans Without Sewing: passo 5, imagem 2 %32
    • Measure and cut out a strip of elastic that is slightly smaller than the distance between the two cuts on the waistband.
  6. How to Downsize Jeans Without Sewing: passo 6, imagem 1 %32 How to Downsize Jeans Without Sewing: passo 6, imagem 2 %32
    • Attach a safety pin onto each end of the elastic strip.
    • Using the safety pin, attach one end of the elastic strip to the waistband directly outside of one of the cuts.
  7. How to Downsize Jeans Without Sewing: passo 7, imagem 1 %32 How to Downsize Jeans Without Sewing: passo 7, imagem 2 %32
    • Slip the free end of the elastic strip into the nearest cut.
    • Push the elastic strip along the waistband through the other cut using the safety pin as an aid.
    • You might need to cut out the tag if the safety pin cannot be pushed through. Cut the thread on both sides of the tag to remove the label.
  8. How to Downsize Jeans Without Sewing: passo 8, imagem 1 %32
    • Similar to the process in step 6, attach the elastic strip just outside of the cut using the remaining safety pin.
    • Be careful not to stick the safety pin all the way through the jeans. The pin should only go through the inside layer of the waistband.
  9. How to Downsize Jeans Without Sewing: passo 9, imagem 1 %32
    • Adjust the excess fabric until it is laying as flat as you can get it.
    • Double check that all the safety pins are properly closed.
Conclusão
To change the size again you can use a looser or tighter elastic band. If a more permanent fix is required, sewing in place of the safety pins is a possible, but more challenging fix. Please note that because of where the cuts are made you will not be able to alter the size drastically the second time you alter them.
9 outras pessoas executaram este guia.
Rachel Wooley
Membro desde: 07/12/17
374 Reputação
Autoria de 1 guia
Equipe
Texas Tech, Team S1-G4, Rauch Summer 2017 Membro de Texas Tech, Team S1-G4, Rauch Summer 2017
TTU-RAUCH-SU17S1G4
Membros da 3
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 19
Últimos 7 dias: 113
Últimos 30 dias: 558
Duração total: 81,119
