Ir para o conteúdo principal
How to Disable Auto Boot
  1. How to Disable Auto Boot, How to Disable Auto Boot: passo 1, imagem 1 %32 How to Disable Auto Boot, How to Disable Auto Boot: passo 1, imagem 2 %32 How to Disable Auto Boot, How to Disable Auto Boot: passo 1, imagem 3 %32
    • Power on your Mac and launch Terminal.
    • To launch Terminal, you can either use Spotlight Search or navigate to Applications / Utilities in Finder and double click the Terminal icon.
    Pergunte ao FixBot
    Comentar
  2. How to Disable Auto Boot: passo 2, imagem 1 %32 How to Disable Auto Boot: passo 2, imagem 2 %32
    • Copy and paste the following command (or type it exactly) into Terminal:
    • sudo nvram AutoBoot=%00
    • Press [return].
    • Your [return] key may also be labeled ⏎ or [enter].
    • If you are prompted for an administrative password, type the password and press [return].
    • Your password will not be displayed in Terminal.
    Pergunte ao FixBot
    Comentar
  3. How to Disable Auto Boot: passo 3, imagem 1 %32
    • You can now safely power down your Mac and remove the bottom case, without it accidentally powering on.
    • Remember, you must still disconnect the battery before servicing internal components.
    Pergunte ao FixBot
    Comentar
  4. How to Disable Auto Boot: passo 4, imagem 1 %32 How to Disable Auto Boot: passo 4, imagem 2 %32 How to Disable Auto Boot: passo 4, imagem 3 %32
    • When your repair is complete and your Mac is successfully reassembled, you can re-enable the Auto Boot feature.
    • sudo nvram AutoBoot=%03
    • Press [return].
    • Alternatively, you may reset your Mac's NVRAM to re-enable Auto Boot.
    Pergunte ao FixBot
    Comentar
Conclusão
Congrats! You're done.
75 outras pessoas executaram este guia.
Jeff Suovanen
Membro desde: 08/06/13
453.482 Reputação
Autoria de 259 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 28.239 guias
29Comentários do guia
hello may i ask, how do u make it Jeff$? mine’s scarlet$ and i want to change it but idk how
srhshahdzan - Responder Compartilhar
You change the your user/Homefolder name
Ben Capehart - Responder Compartilhar
You do not need to change it for the command to work. But if you really do want to for a different reason, rename your home folder name.
Junaayd Shaikh - Responder Compartilhar
I can’t type anything into the terminal…what am I doing wrong?
Linda Sussman - Responder Compartilhar
HELP
it doesn’t work on MacBook Air><
my sister’s pro did work, thanks!! but mine can’t do so. what should I do???
Ching-Hsien Chou - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 71
Últimos 7 dias: 411
Últimos 30 dias: 1,835
Ao todo: 214,329
