Ir para o conteúdo principal
How to Create a Custom Cotton Swab
O que você precisa
  1. How to Create a Custom Cotton Swab, Find a tool: passo 1, imagem 1 %32 How to Create a Custom Cotton Swab, Find a tool: passo 1, imagem 2 %32 How to Create a Custom Cotton Swab, Find a tool: passo 1, imagem 3 %32
    • Find a small object with a pointed end, such as:
    • A toothpick
    • A spudger
    • The end of a flossing pick
    • Avoid metal objects, like paperclips, or anything brittle that might break off in the charging port.
  2. How to Create a Custom Cotton Swab, Separate the cotton: passo 2, imagem 1 %32 How to Create a Custom Cotton Swab, Separate the cotton: passo 2, imagem 2 %32 How to Create a Custom Cotton Swab, Separate the cotton: passo 2, imagem 3 %32
    • Pull off a small part of a cotton ball.
    • You only need a small amount of cotton—enough to create a thin layer around your tool.
  3. How to Create a Custom Cotton Swab, Apply the cotton: passo 3, imagem 1 %32 How to Create a Custom Cotton Swab, Apply the cotton: passo 3, imagem 2 %32 How to Create a Custom Cotton Swab, Apply the cotton: passo 3, imagem 3 %32
    • Wrap the cotton around the tip of your tool.
    • Roll the cotton between your fingers to compress it into a thin layer.
  4. How to Create a Custom Cotton Swab, Remove any excess cotton: passo 4, imagem 1 %32 How to Create a Custom Cotton Swab, Remove any excess cotton: passo 4, imagem 2 %32 How to Create a Custom Cotton Swab, Remove any excess cotton: passo 4, imagem 3 %32
    • Test your cotton swab on your device to see if it fits.
    • If your swab doesn't fit, remove any excess cotton and reroll your cotton so it's compressed and tight along the tip of your tool.
    • If the swab still doesn't fit, you may need to find a different tool altogether.
    • Your custom cotton swab is ready! Return to where you left off in your guide.
Conclusão
For other general electronics skills guides, click here.
26 outras pessoas executaram este guia.
Alex Diaz-Kokaisl
Membro desde: 01/16/22
212.626 Reputação
Autoria de 1.039 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 23.608 guias
1Comentário do guia
My samsung a14 won't charge
Tebogo madibana - Responder
Comentar
Visualizações:
Últimas 24 horas: 24
Últimos 7 dias: 183
Últimos 30 dias: 913
Ao todo: 12,761
