Ir para o conteúdo principal
How to Connect LED Strip Lights
Maxwell Moore
Maxwell Moore e 2 outros colaboradores
Última atualização em 27 de ago de 2024
15 - 45 minutos
Moderado
Introdução
Ir para o passo 1
LED lights often don’t come with connectors and offer no way to connect them in a series to continues one strand. This guide shows exactly how to complete the steps to hang these on your wall connected in a series. This guide is useful for individuals who may purchase multiple sets of lights from different brands or the same brand that may not come with the correct connections. Often times, you receive two light strands with no way to connect them in sequence.
O que você precisa
Ferramentas
  1. How to Connect LED Strip Lights, How to Connect LED Strip Lights: passo 1, imagem 1 %32 How to Connect LED Strip Lights, How to Connect LED Strip Lights: passo 1, imagem 2 %32
    • Attach one strand of lights using the pre applied glue or a hot glue gun where you desire.
    • Make sure you leave a little slack at the end of the strand to connect to the second strand of lights.
  2. How to Connect LED Strip Lights: passo 2, imagem 1 %32 How to Connect LED Strip Lights: passo 2, imagem 2 %32
    • Find the other side labeled RGB with prongs and/or wires and repeat the process from Step 1.
    • Leave slack on the end to reach the other strand.
  3. How to Connect LED Strip Lights: passo 3, imagem 1 %32
    • Once you determine which side you have ended with (either prong side or plate side), you will then determine which set of RGB labeled plates you will connect to.
  4. How to Connect LED Strip Lights: passo 4, imagem 1 %32
    • Using the prong side make sure both sides line up “RGB” to “RGB” on both sides.
    • Place each prong so it coordinates with the correct opposite plate.
    • Push towards the wall into the plate using the prongs and make a firm connection.
  5. How to Connect LED Strip Lights: passo 5, imagem 1 %32
    • Using tape or hot glue firmly secure the center of the connection to the wall or desired area making sure there is little movement in the wires.
    • Try and avoid gluing the metal plates. You may cut off connection from your prongs if not careful.
  6. How to Connect LED Strip Lights: passo 6, imagem 1 %32 How to Connect LED Strip Lights: passo 6, imagem 2 %32 How to Connect LED Strip Lights: passo 6, imagem 3 %32
    • Turn on the light strip to make sure all the lights come on. Test to see if the colors change to make sure they all look correct and match each other.
    • If they do not work correctly restart from step two.
Conclusão
4 outras pessoas executaram este guia.
Gear Up For Future Repairs
Shop all
2Comentários do guia
if you faced the issue of bright then click here to read the complete article on Why Are My LED Strip Lights Not Bright?
Muhammad Sami - Responder
Click here to read the complete article if you want to know how to pair led light remote.
Comentar
Visualizações:
Últimas 24 horas: 25
Últimos 7 dias: 128
Últimos 30 dias: 561
Ao todo: 53,590
