Ir para o conteúdo principal
How to Clean the Condenser Coils in your WRS315SDHW Refrigerator
nicO
nicO e 2 outros colaboradores
Última atualização em June 1, 2023
10 - 20 minutos
Moderado
Introdução
Ir para o passo 1
Use this guide to clean the condenser coils in your WRS315SDHW Whirlpool Refrigerator.
The condenser coils dissipate heat during the cooling cycle. As dust and debris pile onto the coils, the fridge becomes less efficient and must work harder to cool down. If your refrigerator isn't cooling properly, your condenser coils might need some cleaning.
  1. How to Clean the Condenser Coils in your WRS315SDHW Refrigerator, Safety precautions: passo 1, imagem 1 %32
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. How to Clean the Condenser Coils in your WRS315SDHW Refrigerator, Unfasten the rear panel: passo 2, imagem 1 %32 How to Clean the Condenser Coils in your WRS315SDHW Refrigerator, Unfasten the rear panel: passo 2, imagem 2 %32 How to Clean the Condenser Coils in your WRS315SDHW Refrigerator, Unfasten the rear panel: passo 2, imagem 3 %32
    • Use a 1/4 inch socket wrench, or a flathead screwdriver, to remove the seven 16.2 mm-long screws securing the rear panel.
    • Use a 1/4 inch socket wrench to loosen the screw securing the water hose enough for the rear panel to freely move.
  3. How to Clean the Condenser Coils in your WRS315SDHW Refrigerator, Remove the rear panel: passo 3, imagem 1 %32 How to Clean the Condenser Coils in your WRS315SDHW Refrigerator, Remove the rear panel: passo 3, imagem 2 %32 How to Clean the Condenser Coils in your WRS315SDHW Refrigerator, Remove the rear panel: passo 3, imagem 3 %32
    • Pull the rear panel off the chassis to remove it.
  4. How to Clean the Condenser Coils in your WRS315SDHW Refrigerator, Open the doors: passo 4, imagem 1 %32 How to Clean the Condenser Coils in your WRS315SDHW Refrigerator, Open the doors: passo 4, imagem 2 %32 How to Clean the Condenser Coils in your WRS315SDHW Refrigerator, Open the doors: passo 4, imagem 3 %32
    • Depending on your repair, open one or both doors.
  5. How to Clean the Condenser Coils in your WRS315SDHW Refrigerator, Unfasten the front panel: passo 5, imagem 1 %32 How to Clean the Condenser Coils in your WRS315SDHW Refrigerator, Unfasten the front panel: passo 5, imagem 2 %32 How to Clean the Condenser Coils in your WRS315SDHW Refrigerator, Unfasten the front panel: passo 5, imagem 3 %32
    • Use a Phillips driver to remove the two 15.2 mm-long screws securing the front panel.
  6. How to Clean the Condenser Coils in your WRS315SDHW Refrigerator, Remove the front panel: passo 6, imagem 1 %32 How to Clean the Condenser Coils in your WRS315SDHW Refrigerator, Remove the front panel: passo 6, imagem 2 %32 How to Clean the Condenser Coils in your WRS315SDHW Refrigerator, Remove the front panel: passo 6, imagem 3 %32
    • Pull the front panel straight off the chassis and remove it.
    • You may have to slightly open the water filter door to remove the front panel completely.
  7. How to Clean the Condenser Coils in your WRS315SDHW Refrigerator, Vacuum the condenser coils: passo 7, imagem 1 %32 How to Clean the Condenser Coils in your WRS315SDHW Refrigerator, Vacuum the condenser coils: passo 7, imagem 2 %32
    • Vacuum or brush any dust or debris clinging to the black condenser coils.
Conclusão
Repair didn’t go as planned? Ask our Answers community for help.
nicO
Membro desde: 04/14/15
15.927 Reputação
Autoria de 89 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 10
Ao todo: 195
