Ir para o conteúdo principal
How to Clean Calcium Deposits From a Sprinkler Head
Max Warrick
Max Warrick e um outro colaborador
Última atualização em August 25, 2023
10 minutos
Fácil
Introdução
Ir para o passo 1
This guide will demonstrate how to remove the collection basket inside your sprinkler and how to wash out calcium deposits to allow better water flow after being dormant for the winter. The type of sprinkler head this guide applies to is the Rain Bird adjustable 4in. Pop-up Spray Head. The project doesn't require two people but it makes the cleaning process easier and quicker to complete. The time to clean one head is about 10 minutes.
O que você precisa
  1. How to Clean Calcium Deposits From a Sprinkler Head, How to Clean Calcium Deposits From a Sprinkler Head: passo 1, imagem 1 %32 How to Clean Calcium Deposits From a Sprinkler Head, How to Clean Calcium Deposits From a Sprinkler Head: passo 1, imagem 2 %32
    • Place your fingers under the edges of the smaller circle, then slowly lift the head.
    • Keep a hose close by to make it easier to clean the basket.
  2. How to Clean Calcium Deposits From a Sprinkler Head: passo 2, imagem 1 %32 How to Clean Calcium Deposits From a Sprinkler Head: passo 2, imagem 2 %32
    • Twist the head counter clockwise to remove the sprinkler head from the neck, exposing the basket.
  3. How to Clean Calcium Deposits From a Sprinkler Head: passo 3, imagem 1 %32 How to Clean Calcium Deposits From a Sprinkler Head: passo 3, imagem 2 %32
    • If working with two people, use one hand to hold the base of the neck so the sprinkler doesn't fall back into the body of the sprinkler.
    • If working by yourself, slowly release the neck back down. It is still retrievable by twisting the head back on and repeating the process in step 2.
  4. How to Clean Calcium Deposits From a Sprinkler Head: passo 4, imagem 1 %32
    • Use the hose to wash out the basket of any dirt or calcium deposits.
  5. How to Clean Calcium Deposits From a Sprinkler Head: passo 5, imagem 1 %32
    • Reassemble the head, placing back the basket in the center of the neck and twisting the head clockwise to tighten it down.
  6. How to Clean Calcium Deposits From a Sprinkler Head: passo 6, imagem 1 %32
    • Release the neck and the sprinkler is clean and ready for use.
Conclusão
Once the head is reassembled the water flow should no longer be obstructed and should regain the full range of spray.
Max Warrick
Membro desde: 07/03/23
133 Reputação
Autoria de 1 guia
1Comentário do guia
question: What is the flathead screw in the center of the sprinkler head for?
David Franco - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 43
Ao todo: 451
