Ir para o conteúdo principal
How To Reset a Suitcase Lock
Lisha Li
Lisha Li e 2 outros colaboradores
Última atualização em September 29, 2023
5 - 15 minutos
Fácil
Introdução
Ir para o passo 1
For travel, luggage is an indispensable item. During the trip, we must set a password for the suitcase to ensure the safety of the contents. But the password can be easily forgotten and neglected, so opening the suitcase is a more difficult thing. If you do forget the combination, follow this guide to reset the combination on your suitcase lock.
  1. How To Reset a Suitcase Lock, How To Reset a Suitcase Lock: passo 1, imagem 1 %32 How To Reset a Suitcase Lock, How To Reset a Suitcase Lock: passo 1, imagem 2 %32
    • Set the suitcase down with the combination lock facing up.
  2. How To Reset a Suitcase Lock: passo 2, imagem 1 %32
    • Turn a flashlight towards the lock, so that you can see the small details.
  3. How To Reset a Suitcase Lock: passo 3, imagem 1 %32 How To Reset a Suitcase Lock: passo 3, imagem 2 %32 How To Reset a Suitcase Lock: passo 3, imagem 3 %32
    • Rotate the three gears together so that the grooved part of each gear faces the outside.
    • Correct: Gear faces the outside.
    • Gear faces the inside.
  4. How To Reset a Suitcase Lock: passo 4, imagem 1 %32
    • Remember the number of the three gears when the groove part is on the outside.
    • As of now the code number of the three gears is 181.
  5. How To Reset a Suitcase Lock: passo 5, imagem 1 %32
    • Add 5 to each of the three numbers. For example, my numbers are 181. After adding 5, the code to my lock would be 636.
    • Turn the numbers on the lock to 636, and then unlock the lock.
  6. How To Reset a Suitcase Lock: passo 6, imagem 1 %32 How To Reset a Suitcase Lock: passo 6, imagem 2 %32
    • Sometimes the difference is not 5 from the grooved spots. In this case, you can try to increase the numbers after adding 5.
    • For example, if 636 does not work, try to add 6 to the three numbers. Then the code is 747 and attempt to unlock the lock. Continue to add 7, then 8 to try, until it can be opened.
  7. How To Reset a Suitcase Lock: passo 7, imagem 1 %32 How To Reset a Suitcase Lock: passo 7, imagem 2 %32
    • When I added 8 and my number was 969, the lock unlocked. We successfully opened the suitcase!
    Hi . I tried the method . There are small little dent like thing ( ig groove ) on the 444 combination ( on each 4 4 4 gear ) . Then I started to add each gear by 1-9 simultaneously. But still It didn't open
    Kindly help
    Divyaditya Singh - Responder
Conclusão
After reading my guide, you will never encounter the problem that the suitcase cannot be opened without remembering the password. It can be solved anytime, anywhere.
5 outras pessoas executaram este guia.
Lisha Li
Membro desde: 09/17/21
445 Reputação
Autoria de 2 guias
Equipe
4 comentários
OMG! A big THANK YOU!!! It worked.
Edward Lee - Responder
Amazing. This worked for me
Leena Daykin - Responder
It worked for me too
georgeteach - Responder
Surprised ! And grateful also to the author. I opened the lock with forgotten combination in just 3 minutes.
Chandrashekhar Dadhekar - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 20
Últimos 7 dias: 107
Últimos 30 dias: 494
Ao todo: 49,417
