How To Replace the Wheels on a Trash Can
Introdução
Ir para o passo 1The life of a trash can is dirty and rough. With those conditions, it can be expected that something will eventually break. Here is our guide to replacing the wheels of a 96 gallon toter trash can in the case that it does break. No experience is necessary, only a couple tools and these steps will get you a trash can that can roll again.
O que você precisa
Position the flathead screwdriver on the tab of the pal-nut in the center of the wheel.
Position the rubber mallet on top of the flathead screwdriver.
Hit the flathead screwdriver with the rubber mallet a couple times for each tab.
Now that your trash can is up and rolling again, you can now pat yourself on the back for a job well done!
Uma outra pessoa concluiu este guia.
Gear Up For Future Repairs
Shop all6Comentários do guia
What size pal nuts on trash barrels
Putting wheels back on trash barrel.Need to replace pal nut and would like to know if there is a standard size to purchase
Hi there!
Upon looking at this specific replacement kit, the Pal-Nut size they used is 5/8”. Since you may have a different trash can with a different size axle, you should refer to any replacement kits made online and see what size Pal-Nut they use.
I am a 65 year grandmother and I replaced the wheels on my 20 year Toter with no issues, Found the repacement parts online. Proud of myself
It has a solid plastic outside and no nut
Judy Spaul - Responder
