Ir para o conteúdo principal
How To Repair a Hole in a Crochet Blanket
Aisha Ali
Aisha Ali e um outro colaborador
Última atualização em January 15, 2025
35 - 45 minutos
Moderado
Guia do aluno destaque
Introdução
Ir para o passo 1
Even the most well-made crochet blanket can start to look a little shabby after years of love and use. It's not uncommon for the yarn loops on a crochet project to unravel over time and a hole starts to form. Unless your blanket is literally hanging on by a thread, don’t throw it away yet! This guide will walk you through how to repair a hole in a crochet blanket so that it looks good as new.
Note: The exact repair method will depend on the construction of the blanket and the stitch pattern used. This guide works best for projects worked in three double-crochet clusters, also known as a granny stitch.
  1. How To Repair a Hole in a Crochet Blanket, How To Repair a Hole in a Crochet Blanket: passo 1, imagem 1 %32
    • Carefully unpick any torn or damaged stitches that have become separated from the main body of the blanket.
    • Take your time while separating the strands. Pulling too hard may cause additional damage to the blanket.
  2. How To Repair a Hole in a Crochet Blanket: passo 2, imagem 1 %32 How To Repair a Hole in a Crochet Blanket: passo 2, imagem 2 %32
    • Secure any loose or dangling stitches by threading the bottom loops with stitch markers and clasping them closed.
    • This will keep the stitches from accidentally unraveling and making the hole larger.
  3. How To Repair a Hole in a Crochet Blanket: passo 3, imagem 1 %32
    • After you’ve secured all of the loose stitches, it's time to fill in the hole. Join your new yarn to the first stitch on the bottom row.
    • If you can’t locate the exact yarn used in the blanket, try your best to match the color, material, and weight of the original yarn as closely as possible.
  4. How To Repair a Hole in a Crochet Blanket: passo 4, imagem 1 %32 How To Repair a Hole in a Crochet Blanket: passo 4, imagem 2 %32 How To Repair a Hole in a Crochet Blanket: passo 4, imagem 3 %32
    • Follow the original stitch pattern, starting at the bottom row and working from right to left.
    • This example uses a three double-crochet cluster, also known as a granny cluster.
    • When you're finished with a row, join with a slip knot and fasten off. Start the next row and repeat Steps 3 and 4.
  5. How To Repair a Hole in a Crochet Blanket: passo 5, imagem 1 %32 How To Repair a Hole in a Crochet Blanket: passo 5, imagem 2 %32
    • When you reach the last row, take out the stitch markers in the top row of stitches.
    • Insert your hook through the bottom loops of the stitch. Yarn over and pull through all of the loops on your hook.
    • This attaches the top row of existing stitches to your new stitches below.
    • Repeat for the rest of the row.
  6. How To Repair a Hole in a Crochet Blanket: passo 6, imagem 1 %32
    • Once you are finished, fasten off and weave in your ends.
    Wow great instructions!
    Mamadukes - Responder
Linha de Chegada
6 outras pessoas executaram este guia.
1Comentário do guia
Thank you for your post! This was extremely helpful as I thought I would have to discard an afghan my late mother had made after my dog decided it was his chew toy.
MRAYCLERK - Responder
Comentar
Visualizações:
Últimas 24 horas: 7
Últimos 7 dias: 41
Últimos 30 dias: 243
Ao todo: 16,453
