Ir para o conteúdo principal
How To Patch A Hole In The Wall
Joseph Garcia
Joseph Garcia e 4 outros colaboradores
Última atualização em July 15, 2020
1 hora
Fácil
Introdução
Ir para o passo 1
For your shoddy walls that have holes in them, here is a quick and easy guide to completely repair the holes.
  1. How To Patch A Hole In The Wall, How To Patch A Hole In The Wall: passo 1, imagem 1 %32 How To Patch A Hole In The Wall, How To Patch A Hole In The Wall: passo 1, imagem 2 %32 How To Patch A Hole In The Wall, How To Patch A Hole In The Wall: passo 1, imagem 3 %32
    • Sand down the hole and the area surrounding. This is in order to get paint off the wall.
  2. How To Patch A Hole In The Wall: passo 2, imagem 1 %32 How To Patch A Hole In The Wall: passo 2, imagem 2 %32
    • Use the rag and the toothbrush to clean off any excess rubble near the hole.
  3. How To Patch A Hole In The Wall: passo 3, imagem 1 %32
    • Follow the directions on the spackle box to prepare the spackle for application.
    • Although all spackle brands are different, spackle should have a consistency similar to toothpaste when mixed with water.
  4. How To Patch A Hole In The Wall: passo 4, imagem 1 %32 How To Patch A Hole In The Wall: passo 4, imagem 2 %32 How To Patch A Hole In The Wall: passo 4, imagem 3 %32
    • Take the spackle mix and apply it to the hole.
    • Make sure to layer the spackle evenly and remove excess spackle.
  5. How To Patch A Hole In The Wall: passo 5, imagem 1 %32
    • Wait 30-45 minutes for the spackle patch to dry.
    • Wait time may vary depending on the depth of the hole and spackle mix used.
  6. How To Patch A Hole In The Wall: passo 6, imagem 1 %32
    • Make sure the spackle is dry.
    • Sand the spackle until it is smooth and flush with the wall.
Conclusão
Now your wall should be looking as good as new!
3 outras pessoas executaram este guia.
Joseph Garcia
Membro desde: 09/29/15
293 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 17-2, Green Fall 2015 Membro de Cal Poly, Team 17-2, Green Fall 2015
CPSU-GREEN-F15S17G2
4 Membros
Autoria de 9 guias
1Comentário do guia
I suggest using a sanding sponge or block in step 6
Dennis - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 31
Ao todo: 1,899
