Hover-1 XLS Battery Replacement
Introdução
Ir para o passo 1If the bike is not performing at its maximum capability, its battery may be corroded, and you should replace it as soon as possible. Before beginning this guide, you will need power tools or a chemical remover to deal with Teflon tape on the screws.
O que você precisa
Remove the four, 12mm Hex #3 screws located on the bottom half of the battery compartment.
Remove the adhesive holding the wires tightly.
Pull on both sides of the wire connections.
Uma outra pessoa concluiu este guia.
15Comentários do guia
That looks easy enough to do. My problem is finding a replacement battery. Do you have any idea where they are available?
David did you happen to find one? Please let me know I've been looking for one
If anyone find a 1:1 replacement battery for this, or at the very least a wiring diagram, please post it as it's near impossible to find anything on this thing in 2022.
So the yellow and a red are for the ignition and the other red and black ig is a standard ground and positive with the white being I think the temperature sensore wire. Hope this helps also trying to find a replacement and may try wiring one up.
has anyone been able to find the battery replacement ? any links ?
I agree 100% dam Battery is impossible to find with the same Plugs
Cannot find a battery ANYWHERE. Looks like I'm replacing the scooter with a more reputable brand like Segway
Wow, so I’m not the only one that’s having trouble finding a battery. %#*@ that sucks. I even went as far as trying to contact the maker of the battery, but none of the websites in English,
Try checking this out because the batteries aren’t branded by Hover-1:
I hope it helps someone… It’s pretty expensive but it’s the closest I’ve found so far. Compare it with your battery and see if it’s the same. Good luck!
My battery is not in this location other is a control box. the fat bar that is attached to the front forks and goes to the rear wheels has 4 screws at the front. I removed them and tried to take top cover off. Cover would not come off. I read that you cannot remove battery. Do u have a clue? Thanks Tommy
Thomas Watts I meant to say where u say the battery is located in the front forks when I removed the cover my scooter has a control box. Where else could battery be at. Like I said the cross bar from the front forks to rear wheel would be the only other place and when I removed the 4 screws I could not get cover off. It was a new present gifted to me. Has never been abused. It is as new condition. I am trying to locate Manuel that came with it. Thanks
I am having the same problems! Did you find the manual? How about a battery replacement?
I need new battery to find with same plug please supply new battery I will any cost
Please reply me
Hi,
I can't find this battery anymore.
Planning to assemble my own set of batteries,
Can you tell me the yellow and white wires NTC wires or communication wires?
Tks
realceragx - Responder
