Ir para o conteúdo principal
Hair Dryer Fan/ Motor Assembly Replacement
Mitch
Mitch e 9 outros colaboradores
Última atualização em September 14, 2024
Nenhuma estimativa
Moderado
Instead of buying a new hairdryer, simply use this guide to replace the motor on your old one!
O que você precisa
Ferramentas
Exibir mais…
  1. Hair Dryer Fan/ Motor Assembly Replacement, Nozzle: passo 1, imagem 1 %32 Hair Dryer Fan/ Motor Assembly Replacement, Nozzle: passo 1, imagem 2 %32
    • Remove the black air concentrating nozzle by gently twisting and pulling the nozzle.
    • If nozzle is not attached, skip to next step.
  2. Hair Dryer Fan/ Motor Assembly Replacement, Grating: passo 2, imagem 1 %32
    • Using a screwdriver, remove the screw located underneath the air concentrating nozzle. This screw attaches the hair dryer body to the hair dryer grating.
    • For most hair dryers, use a Phillips #1 screwdriver. For hair dryers with smaller screws, consider using a Phillips #00 screwdriver.
  3. Hair Dryer Fan/ Motor Assembly Replacement: passo 3, imagem 1 %32
    • Detach the hair dryer grating from the body by gently twisting the grating from side to side.
  4. Hair Dryer Fan/ Motor Assembly Replacement: passo 4, imagem 1 %32
    • Separate the hair dryer grating into the three pieces seen in the image.
  5. Hair Dryer Fan/ Motor Assembly Replacement, Fan/ Motor Assembly: passo 5, imagem 1 %32
    • Locate the screws on the handle and remove with a Phillips screwdriver.
  6. Hair Dryer Fan/ Motor Assembly Replacement: passo 6, imagem 1 %32
    • Carefully separate the plastic case with the Plastic Opening Tool.
  7. Hair Dryer Fan/ Motor Assembly Replacement: passo 7, imagem 1 %32
    • After removing the plastic case, locate the fan towards the back of the hair dryer.
  8. Hair Dryer Fan/ Motor Assembly Replacement: passo 8, imagem 1 %32
    • Remove the screw that is holding the fan to the motor using a Phillips screwdriver.
  9. Hair Dryer Fan/ Motor Assembly Replacement: passo 9, imagem 1 %32
    • Remove the screws holding the motor to the casing using a Phillips screwdriver.
    • NOTE: This may be unnecessary if the fan can be removed without using a screwdriver.
  10. Hair Dryer Fan/ Motor Assembly Replacement: passo 10, imagem 1 %32
    • Isolate the fan from the rest of the dryer.
    • Remove the screws holding the motor in place. Replace with the new component.
  11. Hair Dryer Fan/ Motor Assembly Replacement: passo 11, imagem 1 %32
    • Solder the wires to the motor. Refer to the soldering page below, which will help you replace this component.
    • Soldering Skills
Conclusão
Mitch
Membro desde: 10/04/12
34 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 24-29, Regan Fall 2012 Membro de Cal Poly, Team 24-29, Regan Fall 2012
CPSU-REGAN-F12S24G29
5 Membros
Autoria de 11 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 31
Últimos 30 dias: 70
Ao todo: 16,609
