Ir para o conteúdo principal
HP Slate 7 Extreme 4400US Rear-Facing Camera Replacement
Riley Wells
Riley Wells e 3 outros colaboradores
Última atualização em October 4, 2018
10 minutos
Moderado
For this guide, you will need the following tools: plastic opening tool, spudger, PH 000 screw bit.
O que você precisa
Ferramentas
  • iFixit Opening Tool
    iFixit Opening Tool
  • Phillips #000 Screwdriver
  • Spudger
    Spudger
Exibir mais…
  1. HP Slate 7 Extreme 4400US Rear-Facing Camera Replacement, Back Cover: passo 1, imagem 1 %32 HP Slate 7 Extreme 4400US Rear-Facing Camera Replacement, Back Cover: passo 1, imagem 2 %32 HP Slate 7 Extreme 4400US Rear-Facing Camera Replacement, Back Cover: passo 1, imagem 3 %32
    • Use the plastic opening tool to separate the back cover from the tablet. Carefully use the tool to pry open the sides, going around the entire tablet to lift the sides up.
    • Once all sides have been pried up, pull the cover off and place it to the side.
  2. HP Slate 7 Extreme 4400US Rear-Facing Camera Replacement, Rear-Facing Camera: passo 2, imagem 1 %32 HP Slate 7 Extreme 4400US Rear-Facing Camera Replacement, Rear-Facing Camera: passo 2, imagem 2 %32 HP Slate 7 Extreme 4400US Rear-Facing Camera Replacement, Rear-Facing Camera: passo 2, imagem 3 %32
    • Pull back the tape holding the the camera's connector strip to the device.
    • Use the nylon spudger to flip up the black retaining flap of the zero insertion force (ZIF) connector holding the strip in place.
    • Gently pull the camera's connecting strip out from the port.
Conclusão
Uma outra pessoa concluiu este guia.
Riley Wells
Membro desde: 09/15/16
111 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 11-4, Blackwell Fall 2016 Membro de USF Tampa, Team 11-4, Blackwell Fall 2016
USFT-BLACKWELL-F16S11G4
4 Membros
Autoria de 16 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 21
Ao todo: 201
