HP Pavilion dv6000 LCD Screen Replacement
Introdução
Ir para o passo 1Replace the LCD in your HP Pavilion dv6000.
O que você precisa
Remove rubber screw covers from the LCD screen. The top covers pop off with a fingernail but the two on the bottom may require a screwdriver or flat tool.
Remove the six 7.15mm screws underneath the stoppers. There are four on top and two on bottom.
15 outras pessoas executaram este guia.
1Comentário do guia
after replacing my cracked screen the back light does not show again
