HP Pavilion Sleekbook 15-b000 Motherboard Replacement
40 minutos
Moderado
Introdução
Ir para o passo 1This guide will walk you through the step by step process to remove the mother board from your laptop. You will need to do this if you are having issues with the laptop booting or to remove the WiFi card or RAM.
O que você precisa
Using the spudger to lift up on the white tabs
Pull horizontally on the blue ribbon to disconnect the cables
Quase terminado!
Conclusão
Gear Up For Future Repairs
Shop all
