Ir para o conteúdo principal
HP Pavilion Sleekbook 15- b000 Fan
Sam Barkley
Sam Barkley e 3 outros colaboradores
Última atualização em May 31, 2018
20 minutos
Moderada
The fan is required to ventilate heat from the laptop and keep it from overheating. This guide will show you the steps to remove the fan from your laptop in case the fan is not working, the laptop is overheating, or needs to be replaced because it is making noise.
O que você precisa
Ferramentas
  • Spudger
    Spudger
  • Phillips #1 Screwdriver
  • iFixit Opening Tool
    iFixit Opening Tool
Exibir mais…
  1. HP Pavilion Sleekbook 15- b000 Fan, Battery: passo 1, imagem 1 %32
    • Unplug laptop from adapter and all other devices.
  2. HP Pavilion Sleekbook 15- b000 Fan: passo 2, imagem 1 %32
    • Flip the laptop over with battery facing you.
  3. HP Pavilion Sleekbook 15- b000 Fan: passo 3, imagem 1 %32 HP Pavilion Sleekbook 15- b000 Fan: passo 3, imagem 2 %32
    • Slide the battery lock on the right side open.
    • Slide the Battery release latch on the left side.
  4. HP Pavilion Sleekbook 15- b000 Fan: passo 4, imagem 1 %32
    • Pull battery out.
  5. HP Pavilion Sleekbook 15- b000 Fan, Keyboard: passo 5, imagem 1 %32
    • Remove the two 6.5mm Phillips #1 keyboard screws from bottom of laptop.
  6. HP Pavilion Sleekbook 15- b000 Fan: passo 6, imagem 1 %32
    • Push screwdriver through screw hole top pop the keyboard.
    • Make sure the screen is open.
  7. HP Pavilion Sleekbook 15- b000 Fan: passo 7, imagem 1 %32
    • Pry up the keyboard.
    • The keyboard is still attached by it's ribbon.
  8. HP Pavilion Sleekbook 15- b000 Fan: passo 8, imagem 1 %32
    • Remove keyboard wire by popping latch under blue plastic
  9. HP Pavilion Sleekbook 15- b000 Fan, Case: passo 9, imagem 1 %32
    • Using the spudger to lift up on the white tabs
    • Pull horizontally on the blue ribbon to disconnect the cables
  10. HP Pavilion Sleekbook 15- b000 Fan: passo 10, imagem 1 %32
    • Remove the five 5.5mm Phillips #1 screws from the case
  11. HP Pavilion Sleekbook 15- b000 Fan: passo 11, imagem 1 %32
    • Remove eight 6.5mm Phillips #1 screws from the back cover
  12. HP Pavilion Sleekbook 15- b000 Fan: passo 12, imagem 1 %32 HP Pavilion Sleekbook 15- b000 Fan: passo 12, imagem 2 %32 HP Pavilion Sleekbook 15- b000 Fan: passo 12, imagem 3 %32
    • Starting at a top corner, use the pry tool to split the case.
    • Slowly work around the case, pulling up gently to release the clips.
  13. HP Pavilion Sleekbook 15- b000 Fan, Fan: passo 13, imagem 1 %32
    • Remove the three x 5.5 mm restraining screws.
  14. HP Pavilion Sleekbook 15- b000 Fan: passo 14, imagem 1 %32
    • Pull fan of of heat pipe.
  15. HP Pavilion Sleekbook 15- b000 Fan: passo 15, imagem 1 %32
    • Remove fan.
Conclusão
Sam Barkley
Membro desde: 02/13/18
1.007 Reputação
Autoria de 8 guias
Equipe
USF Tampa, Team S11-G2, Cheng Spring 2018 Membro de USF Tampa, Team S11-G2, Cheng Spring 2018
USFT-CHENG-S18S11G2
Membros da 4
Autoria de 18 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 7
Duração total: 409
