Ir para o conteúdo principal
HP Pavilion 17-f004dx Hard Drive Replacement
Allan Soria
Allan Soria e 5 outros colaboradores
Última atualização em August 20, 2018
20 - 45 minutos
Moderado
Introdução
Ir para o passo 1
The hard drive may malfunction if physically damaged or put under a lot of stress. Use this guide to replace it if the computer won't boot and or is displaying errors.
O que você precisa
Ferramentas
Exibir mais…
  1. HP Pavilion 17-f004dx Hard Drive Replacement, Battery: passo 1, imagem 1 %32
    • Before you remove the battery, make sure the laptop is powered off.
    • Slide the black battery latches inward to remove the battery.
  2. HP Pavilion 17-f004dx Hard Drive Replacement: passo 2, imagem 1 %32
    • Pull the battery out towards you while your fingers are still holding the latches in place.
  3. HP Pavilion 17-f004dx Hard Drive Replacement, CD Drive: passo 3, imagem 1 %32
    • Remove one 7 mm screw with a Phillips #1 screwdriver.
  4. HP Pavilion 17-f004dx Hard Drive Replacement: passo 4, imagem 1 %32 HP Pavilion 17-f004dx Hard Drive Replacement: passo 4, imagem 2 %32 HP Pavilion 17-f004dx Hard Drive Replacement: passo 4, imagem 3 %32
    • Use a metal spudger to push the CD drive out of its slot for removal.
  5. HP Pavilion 17-f004dx Hard Drive Replacement, Front Panel: passo 5, imagem 1 %32
    • Remove fifteen 7 mm screws with a Phillips #1 screwdriver.
  6. HP Pavilion 17-f004dx Hard Drive Replacement: passo 6, imagem 1 %32 HP Pavilion 17-f004dx Hard Drive Replacement: passo 6, imagem 2 %32
    • Remove the thin plastic cover using the flat metal spudger to expose another screw.
    • Remove one 7 mm screw with a Phillips #0 screwdriver.
  7. HP Pavilion 17-f004dx Hard Drive Replacement: passo 7, imagem 1 %32 HP Pavilion 17-f004dx Hard Drive Replacement: passo 7, imagem 2 %32
    • Use a metal spudger to remove the rubber "feet" to expose two screws.
  8. HP Pavilion 17-f004dx Hard Drive Replacement: passo 8, imagem 1 %32
    • Underneath each rubber foot, there is a screw.
    • Use the Phillips #1 screwdriver to remove a 4.8 mm screw on each side.
  9. HP Pavilion 17-f004dx Hard Drive Replacement: passo 9, imagem 1 %32
    • Remove the two black end caps to expose more screws.
    • The end caps will require some force to remove.
  10. HP Pavilion 17-f004dx Hard Drive Replacement: passo 10, imagem 1 %32
    • Remove the following six screws with a Phillips #1 screwdriver:
    • Two 7 mm screws.
    • Two 7 mm screws.
    • Two 4.8 mm screws.
    At step 11 there are only two screws. Those marked in yellow in the picture.
    Paul Clark - Responder
    Step 10, the screws under the end caps. My device also only had the yellow screws in place.
    Jacklyn Collado - Responder
  11. HP Pavilion 17-f004dx Hard Drive Replacement: passo 11, imagem 1 %32
    • Remove two 2.4 mm broadhead screws from the CD Drive bay with a Phillips #0 screwdriver.
  12. HP Pavilion 17-f004dx Hard Drive Replacement: passo 12, imagem 1 %32 HP Pavilion 17-f004dx Hard Drive Replacement: passo 12, imagem 2 %32
    • Flip the laptop back over. Then, with the laptop open, move the plastic prying tool around the top cover to pry it from the enclosure.
  13. HP Pavilion 17-f004dx Hard Drive Replacement: passo 13, imagem 1 %32
    • Partially lift the top cover from the enclosure.
  14. HP Pavilion 17-f004dx Hard Drive Replacement: passo 14, imagem 1 %32 HP Pavilion 17-f004dx Hard Drive Replacement: passo 14, imagem 2 %32
    • Remove the ribbon connecting the power button to the motherboard.
  15. HP Pavilion 17-f004dx Hard Drive Replacement: passo 15, imagem 1 %32 HP Pavilion 17-f004dx Hard Drive Replacement: passo 15, imagem 2 %32
    • Remove the ribbon connecting the mousepad to the motherboard.
  16. HP Pavilion 17-f004dx Hard Drive Replacement: passo 16, imagem 1 %32 HP Pavilion 17-f004dx Hard Drive Replacement: passo 16, imagem 2 %32
    • Remove the ribbon connecting the keyboard to the motherboard.
    • You may now fully lift the front panel from the rest of the laptop.
  17. HP Pavilion 17-f004dx Hard Drive Replacement, Hard Drive: passo 17, imagem 1 %32
    • Lift the black retaining bar that holds down the two hard drive ribbons to unlock them.
  18. HP Pavilion 17-f004dx Hard Drive Replacement: passo 18, imagem 1 %32
    • Gently pull the ribbons out.
  19. HP Pavilion 17-f004dx Hard Drive Replacement: passo 19, imagem 1 %32
    • Lift the hard drive out from the enclosure.
  20. HP Pavilion 17-f004dx Hard Drive Replacement: passo 20, imagem 1 %32 HP Pavilion 17-f004dx Hard Drive Replacement: passo 20, imagem 2 %32 HP Pavilion 17-f004dx Hard Drive Replacement: passo 20, imagem 3 %32
    • Pull the rubber casing away from the hard drive.
Conclusão
9 outras pessoas executaram este guia.
Allan Soria
Membro desde: 09/21/16
632 Reputação
Autoria de 4 guias
Equipe
UC Davis, Team 1-4, Oliver Fall 2016 Membro de UC Davis, Team 1-4, Oliver Fall 2016
UCD-OLIVER-F16S1G4
4 Membros
Autoria de 8 guias
2 comentários
Thank you. Couldn’t figure out why those end caps wouldn’t budge. Dang hidden screws! Kudos!
Shaun Krug - Responder
Greet thank to you ! This tuto was very helpfull for me !
Sambat - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 16
Ao todo: 6,504
