HP Pavilion 15-b109wm RAM Replacement
Introdução
Vá para o passo 1This guide will show you how to replace your Memory Module in your HP Pavilion 15-b109wm. This process will take about 1 hour, and is very tedious. So take your time, complete each task carefully, and you'll have a successful replacement of your Memory Module.
O que você precisa
Ferramenta utilizada neste passo:Heavy-Duty Spudger$4.99
Turn the device onto its side.
Using a heavy duty spudger, gently disengage the keyboard.
Using a JIS #1 screwdriver, remove the five 5mm screws.
Detach the power button cable.
Detach the touch pad cable.
