Ir para o conteúdo principal
HP Pavilion 15-b109wm Battery Replacement
David Atunlute
David Atunlute e 3 outros colaboradores
Última atualização em 5 de nov de 2020
1 - 5 minutos
Muito fácil
Introdução
Ir para o passo 1
If troubleshooting steps have been followed and it is obvious that the problem with the device might be originating from a faulty battery, then follow these steps to replace your device battery. Before starting to poke into the device, ensure to take safety precautions to avoid battery fluid getting on skin or any valuables. This replacement would take about 5 minutes. So, take your time and follow the steps thoroughly and this will be a success.
O que você precisa
Fix Kit
Este kit contém todas as peças e ferramentas necessárias para executar este guia.
Peças
Exibir mais…
  1. HP Pavilion 15-b109wm Battery Replacement, Battery: passo 1, imagem 1 %32
    • Power off the device and disconnect from any power source.
  2. HP Pavilion 15-b109wm Battery Replacement: passo 2, imagem 1 %32
    • Turn the device upside down and ensure the back of the device is facing you.
  3. HP Pavilion 15-b109wm Battery Replacement: passo 3, imagem 1 %32 HP Pavilion 15-b109wm Battery Replacement: passo 3, imagem 2 %32 HP Pavilion 15-b109wm Battery Replacement: passo 3, imagem 3 %32
    • Push both buttons towards one another simultaneously. The battery slightly pops out.
  4. HP Pavilion 15-b109wm Battery Replacement: passo 4, imagem 1 %32 HP Pavilion 15-b109wm Battery Replacement: passo 4, imagem 2 %32 HP Pavilion 15-b109wm Battery Replacement: passo 4, imagem 3 %32
    • Pull out the battery from the device's battery slot.
Conclusão
Gear Up For Future Repairs
Shop all
David Atunlute
Membro desde: 10/30/18
241 Reputação
Autoria de 2 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 13
Ao todo: 658
