Ir para o conteúdo principal
HP Pavilion 14-bk061st Screen Replacement
Mehrab Daemi
Mehrab Daemi e 3 outros colaboradores
Última atualização em June 23, 2020
5 - 10 minutos
Moderado
Using this guide will help you in replacing the screen in your HP Pavilion 14-bk061st.
The screen is an important part of all laptops. Some may consider replacing the screen once issues arise during use such as cracked screens after a fall or vertical or horizontal lines sometimes caused by a loose or frayed video cable.
O que você precisa
Ferramentas
Exibir mais…
  1. HP Pavilion 14-bk061st Screen Replacement, Back Panel: passo 1, imagem 1 %32 HP Pavilion 14-bk061st Screen Replacement, Back Panel: passo 1, imagem 2 %32
    • Remove the three 5.7 JIS #1 screws from the bottom of the laptop.
    • Remove the two 6.7mm JIS #1 screws from underneath the feet of the laptop close to the exhaust vent.
  2. HP Pavilion 14-bk061st Screen Replacement: passo 2, imagem 1 %32
    • Unclip the back plate using a plastic opening tool.
  3. HP Pavilion 14-bk061st Screen Replacement: passo 3, imagem 1 %32
    • Carefully remove the back plate from the laptop.
  4. HP Pavilion 14-bk061st Screen Replacement, Screen: passo 4, imagem 1 %32 HP Pavilion 14-bk061st Screen Replacement, Screen: passo 4, imagem 2 %32
    • Remove the five JIS #1 screws that attach the hinges of the screen to the casing of the laptop.
  5. HP Pavilion 14-bk061st Screen Replacement: passo 5, imagem 1 %32 HP Pavilion 14-bk061st Screen Replacement: passo 5, imagem 2 %32
    • Carefully lift the hinges from the encasing and lift the bottom half of the laptop away from the screen.
  6. HP Pavilion 14-bk061st Screen Replacement: passo 6, imagem 1 %32 HP Pavilion 14-bk061st Screen Replacement: passo 6, imagem 2 %32 HP Pavilion 14-bk061st Screen Replacement: passo 6, imagem 3 %32
    • Use the metal spudger to carefully pry off the plastic encasing around the monitor.
    • Use the outside of the screen to remove the plastic encasing to avoid damaging the screen itself.
  7. HP Pavilion 14-bk061st Screen Replacement: passo 7, imagem 1 %32 HP Pavilion 14-bk061st Screen Replacement: passo 7, imagem 2 %32
    • Remove the four JIS #1 screws holding the screen in place.
  8. HP Pavilion 14-bk061st Screen Replacement: passo 8, imagem 1 %32 HP Pavilion 14-bk061st Screen Replacement: passo 8, imagem 2 %32 HP Pavilion 14-bk061st Screen Replacement: passo 8, imagem 3 %32
    • Carefully remove the sticker covering the wire that connects the screen to the motherboard.
    • Disconnect the cable that is connected to the screen.
  9. HP Pavilion 14-bk061st Screen Replacement: passo 9, imagem 1 %32
    • Remove the screen from the laptop.
Conclusão
Uma outra pessoa concluiu este guia.
Mehrab Daemi
Membro desde: 01/22/20
596 Reputação
Autoria de 4 guias
Equipe
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 15
Ao todo: 938
