HP Pavilion 14-b120dx CPU Cooling Fan Replacement
Introdução
Ir para o passo 1This guide provides the steps to remove and replace the cooling fan on a HP Pavilion 14-b120dx laptop. During this process be advised to power down the device to prevent electrical shock and be careful when applying force to prevent damage to the motherboard or cables.
O que você precisa
Ferramentas
Insert the plastic opening tool between the keyboard and the palm rest.
Pry upwards until the keyboard section detaches from the laptop.
Repeat this around the edge of the entire keyboard.
Unscrew the 10 6.0 mm screws under the keyboard housing with a Philips #0 head screwdriver.
Locate the fan in the upper left hand corner of the laptop.
Remove the cable connecting the fan to the motherboard.
Uma outra pessoa concluiu este guia.
