Ir para o conteúdo principal
HP Omni 10  Speaker Replacement
Alex Miller
Alex Miller e 2 outros colaboradores
Última atualização em January 17, 2025
Nenhuma estimativa
Moderado
Faltando Passos
Melhor Introdução
Faltando detalhes
Introdução
Ir para o passo 1
Using a spudger and a 00 Phillips head screwdriver, this guide will show how to remove a pair of speakers from an HP Omni 10 tablet in roughly 5 to 7 minutes.
O que você precisa
Ferramentas
Exibir mais…
  1. HP Omni 10  Speaker Replacement, Battery: passo 1, imagem 1 %32
    • Remove the back cover from the tablet.
    • The cover is securely fastened to the device and may be difficult to remove.
  2. HP Omni 10  Speaker Replacement: passo 2, imagem 1 %32
    • Push the black plastic security flaps into an upward position.
    • Lift the small tab on the security strips up and peel them across the battery. They will be attached via adhesive.
    • Lift the tab on the strip up and pull it across the battery.
    • The orange strip does not fully detach from the tablet like the other three. It will only detach from one side.
  3. HP Omni 10  Speaker Replacement: passo 3, imagem 1 %32
    • Unscrew the ten 3.3 mm screws securing the battery using a 00 Phillip's head screwdriver.
  4. HP Omni 10  Speaker Replacement: passo 4, imagem 1 %32 HP Omni 10  Speaker Replacement: passo 4, imagem 2 %32
    • Unhook the cord from the edge of the battery.
    • Pull the wire circuit out and down.
  5. HP Omni 10  Speaker Replacement: passo 5, imagem 1 %32 HP Omni 10  Speaker Replacement: passo 5, imagem 2 %32
    • Lift the battery up by its edges and remove it carefully. There will be adhesive holding the battery down.
  6. HP Omni 10  Speaker Replacement, Micro Card Reader: passo 6, imagem 1 %32
    • Unscrew the two 3.3 mm screws using a 00 Phillip's head screwdriver.
  7. HP Omni 10  Speaker Replacement: passo 7, imagem 1 %32
    • Lift and remove micro card reader board.
  8. HP Omni 10  Speaker Replacement, Speaker: passo 8, imagem 1 %32
    • Unscrew the four 3.3 mm screws using a 00 Phillip's head screwdriver.
  9. HP Omni 10  Speaker Replacement: passo 9, imagem 1 %32 HP Omni 10  Speaker Replacement: passo 9, imagem 2 %32
    • Pull the black and white wire connector up to disconnect it.
  10. HP Omni 10  Speaker Replacement: passo 10, imagem 1 %32 HP Omni 10  Speaker Replacement: passo 10, imagem 2 %32
    • Pull the red and black wire connector up to disconnect it.
  11. HP Omni 10  Speaker Replacement: passo 11, imagem 1 %32
    • Lift the speaker set out of their sockets.
    • The speakers will also be attached via adhesive. They may be difficult to remove by hand.
  12. HP Omni 10  Speaker Replacement: passo 12, imagem 1 %32
    • Unhook the left speaker's connector wire to fully remove it from the device.
Conclusão
Uma outra pessoa concluiu este guia.
Alex Miller
Membro desde: 10/11/16
345 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 1-1, Leahy Fall 2016 Membro de USF Tampa, Team 1-1, Leahy Fall 2016
USFT-LEAHY-F16S1G1
3 Membros
Autoria de 10 guias
1Comentário do guia
its order when i will get it please candly I request
Abdul Raheem - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 10
Ao todo: 642
