HP Envy dv7 Hard Drive Replacement
Introdução
Ir para o passo 1This guide is for those who want to replace the hard drive in their HP Envy DV7 laptops.
O que você precisa
Slide the switch shown in the circle above and remove the battery from its housing. No screws are required to remove this part, and the battery should come out with little to no effort.
After the screws around the casing are removed, the casing will slide off opposite to the connector. From here, grip the connector that is connected to the hard drive and gently pull to remove it.
From here, you are free to implement whatever hard drive unit you want to, just make sure to verify that the hard drive is compatible with your computer.
For the casing of the hard drive, I nearly stripped the screws using a PH1. Try a PH0 if you’re having trouble. Great guide, overall.
Uma outra pessoa concluiu este guia.
