Ir para o conteúdo principal
HP Elitebook Folio 9470m RAM Replacement
Kenneth Bowers
Kenneth Bowers e 4 outros colaboradores
Última atualização em February 13, 2023
20 minutos
Moderado
Introdução
Ir para o passo 1
RAM, or random access memory, is short-term storage for your HP Elitebook Folio 9470m. RAM is used by your processor for immediate use as-needed, unlike long-term files written to a hard disk drive. If your computer has slowed considerably or you’re looking for a boost, replacing/upgrading the RAM is a fairly simple and inexpensive first step. The HP Elitebook Folio 9470m laptop comes standard with 16GB of RAM and can be upgraded to a maximum of 16GB with its two (DDR3) slots.
O que você precisa
Ferramentas
  1. HP Elitebook Folio 9470m RAM Replacement, RAM: passo 1, imagem 1 %32
    • Remove battery using this guide here.
  2. HP Elitebook Folio 9470m RAM Replacement: passo 2, imagem 1 %32 HP Elitebook Folio 9470m RAM Replacement: passo 2, imagem 2 %32 HP Elitebook Folio 9470m RAM Replacement: passo 2, imagem 3 %32
    • Unscrew 2 Phillips head screws, lift slightly up and out to remove hard drive cover.
  3. HP Elitebook Folio 9470m RAM Replacement: passo 3, imagem 1 %32 HP Elitebook Folio 9470m RAM Replacement: passo 3, imagem 2 %32 HP Elitebook Folio 9470m RAM Replacement: passo 3, imagem 3 %32
    • Remove the three Phillips screws from the back plate. Pull slightly up and out to remove the plate.
    • These screws are also marked with a small RAM icon.
  4. HP Elitebook Folio 9470m RAM Replacement: passo 4, imagem 1 %32 HP Elitebook Folio 9470m RAM Replacement: passo 4, imagem 2 %32 HP Elitebook Folio 9470m RAM Replacement: passo 4, imagem 3 %32
    • Gently push out the small tabs on either side.
    • The RAM should pop up and easily be taken out from there.
Conclusão
7 outras pessoas executaram este guia.
Kenneth Bowers
Membro desde: 04/08/16
1.432 Reputação
Autoria de 7 guias
Equipe
Um comentário
There are 2 black Philips screws more you have to loose, before you can open the back plate. One on the left side (near wifi card), and on right side.
Mikael Salo - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 25
Últimos 30 dias: 56
Ao todo: 6,734
