Ir para o conteúdo principal
HP Elitebook Folio 9470m Hard Drive Replacement
Kenneth Bowers
Kenneth Bowers e 8 outros colaboradores
Última atualização em January 3, 2024
25 minutos
Moderado
Introdução
Ir para o passo 1
This guide will teach you how to replace a full or faulty hard drive on your HP Elitebook Folio 9470m.
The hard drive is the storage of your device; a faulty hard drive could cause crashes, long load times, excessive noise, and even loss of files.
Hard drives are very sensitive to sudden impacts, any impact could cause scratches on the disk inside the hard drive causing data loss.
Be sure if you have any important files on the hard drive to back them up before beginning the replacement. Make sure that the device is off and disconnected from any external power source before beginning.
O que você precisa
Kits de conserto
Estes kits contêm todas as peças e ferramentas necessárias para executar este guia.
Peças
Ferramentas
Exibir mais…
  1. HP Elitebook Folio 9470m Hard Drive Replacement, Hard Drive: passo 1, imagem 1 %32 HP Elitebook Folio 9470m Hard Drive Replacement, Hard Drive: passo 1, imagem 2 %32
    • Flip laptop over.
  2. HP Elitebook Folio 9470m Hard Drive Replacement: passo 2, imagem 1 %32 HP Elitebook Folio 9470m Hard Drive Replacement: passo 2, imagem 2 %32
    • Remove battery using This guide.
  3. HP Elitebook Folio 9470m Hard Drive Replacement: passo 3, imagem 1 %32 HP Elitebook Folio 9470m Hard Drive Replacement: passo 3, imagem 2 %32 HP Elitebook Folio 9470m Hard Drive Replacement: passo 3, imagem 3 %32
    • Unscrew the 2 Phillips screws.
    • Slide the cover to the left, then remove the cover.
  4. HP Elitebook Folio 9470m Hard Drive Replacement: passo 4, imagem 1 %32
    • Unscrew the 4 Phillips screws securing the hard drive.
  5. HP Elitebook Folio 9470m Hard Drive Replacement: passo 5, imagem 1 %32
    • Remove by gently pulling up on the tab and out.
Conclusão
5 outras pessoas executaram este guia.
Kenneth Bowers
Membro desde: 04/08/16
1.432 Reputação
Autoria de 7 guias
Equipe
2 comentários
Pls I have lost my battery can u help me get another one for my lap please
Hw much will it cost
kingsleysenuduku - Responder
A bit late to the Party but you can find the battery on the main-site of the HP Elitebook Folio 9470m under the section «Parts»
RudiDerHirsch -
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 14
Últimos 30 dias: 76
Ao todo: 9,608
