Ir para o conteúdo principal
HP EliteBook 8530w Battery Replacement
Raymond Kwasneski
Raymond Kwasneski e 3 outros colaboradores
Última atualização em June 4, 2020
1 minuto
Muito fácil
Melhor Introdução
Introdução
Ir para o passo 1
This is a guide that will show you how to replace the battery of an HP EliteBook 8530w.
The battery of a laptop is the most common thing that needs replacing. Luckily, it is the easiest thing to replace for this laptop.
  1. HP EliteBook 8530w Battery Replacement, Battery: passo 1, imagem 1 %32 HP EliteBook 8530w Battery Replacement, Battery: passo 1, imagem 2 %32
    • Turn the laptop off then place it down so that the back is facing up.
    • Slide the battery release switch to the left and hold it there.
  2. HP EliteBook 8530w Battery Replacement: passo 2, imagem 1 %32 HP EliteBook 8530w Battery Replacement: passo 2, imagem 2 %32
    • Pull the battery away upward and away from the laptop while continuing to hold the release switch.
    • Once the battery is removed from the laptop, you may release the switch.
    • To properly dispose of your battery, look for the closest location that accepts electronic waste in your area and drop it off there.
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 32
Ao todo: 559
