Ir para o conteúdo principal
HP Compaq 515 Battery Replacement
Kirsten Harnden
Kirsten Harnden e 2 outros colaboradores
Última atualização em June 5, 2018
5 minutos
Muito fácil
Introdução
Ir para o passo 1
This replacement guide is quite simple for people who aren't very tech savvy. It is fast and simple to do on your own. This replacement would be necessary if the device can't run without being plugged into a power source. Make sure the laptop is off before proceeding with the replacement.
  1. HP Compaq 515 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Turn the laptop over, the battery is located along the top of the device.
  2. HP Compaq 515 Battery Replacement: passo 2, imagem 1 %32 HP Compaq 515 Battery Replacement: passo 2, imagem 2 %32
    • There are two rectangular tabs on the battery. With both hands, push each tab towards the center to free the battery from the device.
    • keeping the tabs pushed in, slide the battery upwards.
  3. HP Compaq 515 Battery Replacement: passo 3, imagem 1 %32
    • The battery should pop off and release from the device.
Conclusão
Uma outra pessoa concluiu este guia.
Kirsten Harnden
Membro desde: 03/13/18
259 Reputação
Autoria de 2 guias
Equipe
0 comentários
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 9
Ao todo: 398
