GoPro Karma Arm Replacement
Introdução
Replacing an arm on the Karma can be done in less than 20 minutes. There are four main steps: removing the landing gear, removing the old arm, installing the new arm, reattaching the landing gear. This video will walk you through each step.
O que você precisa
Peças
Ferramentas
Instruções em vídeo
3 outras pessoas executaram este guia.
3 comentários
Juste merci !
cedricgaeta - Responder
Can someone tell me what tools are needed? I’m looking first to see if I can repait a slightly cracked arm before needing to replace?
lenodski - Responder
The only tool needed is a 2.5mm hex key.
Blake Klein -
