Ir para o conteúdo principal
GoPro Hero LCD Screen Replacement
River Drake
River Drake e 4 outros colaboradores
Última atualização em 26 de mai de 2021
15 - 20 minutos
Moderado
Fotos de ação
Introdução
Ir para o passo 1
If for some reason, your screen is dysfunctional, you can replace it. Since it is near the bottom of the camera, it is not easy to replace. Grab your screwdrivers and tweezers and let's go!
O que você precisa
Peças
Ferramentas
Exibir mais…
  1. GoPro Hero LCD Screen Replacement, Casing: passo 1, imagem 1 %32
    • Power off your GoPro before beginning disassembly.
    • Unclip the black latch to the camera case and open the case.
  2. GoPro Hero LCD Screen Replacement: passo 2, imagem 1 %32
    • Gently pry the back open by inserting a metal spudger between the case and back panel.
  3. GoPro Hero LCD Screen Replacement: passo 3, imagem 1 %32
    • Disconnect the battery from the motherboard by unplugging the red, white, and black wires from the white adapter.
  4. GoPro Hero LCD Screen Replacement: passo 4, imagem 1 %32
    • Disconnect the ribbon cable from the lens by lifting the black latch and gently pulling the ribbon cable from the socket.
  5. GoPro Hero LCD Screen Replacement: passo 5, imagem 1 %32
    • Use a Phillips screwdriver (PH000) to remove the four screws around the white plastic piece.
    • Make sure to keep track of these screws as they are very small.
  6. GoPro Hero LCD Screen Replacement: passo 6, imagem 1 %32
    • Carefully remove the motherboard and white plastic piece from the case.
  7. GoPro Hero LCD Screen Replacement, LCD Screen: passo 7, imagem 1 %32 GoPro Hero LCD Screen Replacement, LCD Screen: passo 7, imagem 2 %32
    • Remove the larger ribbon cable from the daughter board by lifting the black latch and pulling the ribbon cable gently from the socket.
    • Disconnect the smaller ribbon cable leading from the white plastic piece by simply pulling it from the socket.
    gostaria de compra essa parte completa
    nishiura447 - Responder
  8. GoPro Hero LCD Screen Replacement: passo 8, imagem 1 %32
    • Separate the motherboard from the white piece of plastic.
  9. GoPro Hero LCD Screen Replacement: passo 9, imagem 1 %32
    • Remove the ribbon cable from the motherboard by simply pulling the cable from the socket.
  10. GoPro Hero LCD Screen Replacement: passo 10, imagem 1 %32 GoPro Hero LCD Screen Replacement: passo 10, imagem 2 %32
    • Separate the LCD screen from the motherboard.
Conclusão
5 outras pessoas executaram este guia.
Gear Up For Future Repairs
Shop all
River Drake
Membro desde: 04/02/15
1.047 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 12-2, Lancaster Spring 2015 Membro de Cal Poly, Team 12-2, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G2
4 Membros
Autoria de 18 guias
3Comentários do guia
Where do you buy the replacement lcd
Anthony Volatile - Responder
I can find the screen but is it compatible with the Hero+
Brian Casado - Responder
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 32
Últimos 30 dias: 148
Ao todo: 25,660
