Ir para o conteúdo principal
GoPro Hero 3 Silver Image Sensor Replacement
Jose Villa
Jose Villa e 4 outros colaboradores
Última atualização em 29 de mai de 2021
Nenhuma estimativa
Fácil
Melhor Introdução
O que você precisa
Peças
Ferramentas
  • T4 Torx Screwdriver
    T4 Torx Screwdriver
  • Phillips #00 Screwdriver
  • Spudger
    Spudger
  • iFixit Opening Tool
    iFixit Opening Tool
Exibir mais…
  1. GoPro Hero 3 Silver Image Sensor Replacement, Battery: passo 1, imagem 1 %32 GoPro Hero 3 Silver Image Sensor Replacement, Battery: passo 1, imagem 2 %32
    • Pull back on the tab on the back of GoPro to open the battery cover.
  2. GoPro Hero 3 Silver Image Sensor Replacement: passo 2, imagem 1 %32
    • Pull the battery out using the tab.
  3. GoPro Hero 3 Silver Image Sensor Replacement, Image Sensor: passo 3, imagem 1 %32 GoPro Hero 3 Silver Image Sensor Replacement, Image Sensor: passo 3, imagem 2 %32
    • Use the plastic opening tool to remove the faceplate.
    • There is some adhesive and clips so be careful and the faceplate should pop right off.
  4. GoPro Hero 3 Silver Image Sensor Replacement: passo 4, imagem 1 %32 GoPro Hero 3 Silver Image Sensor Replacement: passo 4, imagem 2 %32
    • Now that the faceplate is off, it is time to remove the 4 screws on each corner.
    • Use the T4 tool bit from the iFixit toolkit in order to remove the 4 screws on each corner.
  5. GoPro Hero 3 Silver Image Sensor Replacement: passo 5, imagem 1 %32 GoPro Hero 3 Silver Image Sensor Replacement: passo 5, imagem 2 %32
    • Note: Make sure you remove the door cover of the USB, mini HDMI, and SD port before. Separating the motherboard will be easier.
    • Using the plastic opening tool, slowly pry open the motherboard assembly.
  6. GoPro Hero 3 Silver Image Sensor Replacement: passo 6, imagem 1 %32 GoPro Hero 3 Silver Image Sensor Replacement: passo 6, imagem 2 %32
    • Use the spudger to gently pry off the connector of the housing to the motherboard.
    • You should now have the motherboard assembly and the housing separated.
  7. GoPro Hero 3 Silver Image Sensor Replacement: passo 7, imagem 1 %32 GoPro Hero 3 Silver Image Sensor Replacement: passo 7, imagem 2 %32
    • Use the spudger to remove the heat shield tape and detach the image sensor from the motherboard.
    • Using the T4 Torx toolbit, remove the 4 screws that connect the sensor to the lens.
  8. GoPro Hero 3 Silver Image Sensor Replacement: passo 8, imagem 1 %32 GoPro Hero 3 Silver Image Sensor Replacement: passo 8, imagem 2 %32
    • Remove the silver connector of the image sensor from the motherboard using the spudger to pry it off.
    • You should now be able to remove the image sensor by simply pulling it.
    Where i can buy the image sensor, and for how much
    Yudha prabowo - Responder
Conclusão
Gear Up For Future Repairs
Shop all
Jose Villa
Membro desde: 04/01/15
297 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 24-7, Lancaster Spring 2015 Membro de Cal Poly, Team 24-7, Lancaster Spring 2015
CPSU-LANCASTER-S15S24G7
3 Membros
Autoria de 21 guias
2Comentários do guia
After the sensor has been replaced, does the camera need any catibration?
enrilazaro - Responder
Your pictures are really dark.
Nick Ruiz - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 24
Ao todo: 2,050
